Question about Saws
Have Craftsman 10" table saw mod #137.248830. Was working fine but in the middle of a project it would not turn on. GFCI wasn't tripped, removed saw assembly from base and inverted to test connections, all were tight. Removed blade, tried switch with saw upside down on base, nothing. Tested power to switch, present; switch to motor, not; tested reset, nothing. Cleaned all connections, tried switch repeatedly and about 5th try it worked. about 6 times. reassembled unit and attempted to complete my cut only to get halfway through and it quit again. Same scenario, disassembled, tested all circuits and cables and grounds. Power to switch, intermittent from switch to motor. Where can I get a new switch and what's it gonna cost me ? I think I've covered all the bases as far as diagnostics go, unless there's something you can see I may have left out. Steve B
  • 384 Answers
SOURCE: key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Posted on Sep 14, 2009
  • 548 Answers
SOURCE: Can I use a dado blade on my craftsman tablesaw
yes you can and here is a nice online manual that is free and you can even print out if you like
http://dl.owneriq.net/e/e99c86ed-3ba5-4bb5-a567-3b4fffebfc1f.pdf
it will show you all of the saws usues and attachments including dado
Posted on Sep 25, 2009
Testimonial: "Thanks, I was pleasantly surprised with the promptness of your response. "
  • 130 Answers
SOURCE: I HAVE A CRAFTSMAN MODEL # 137.218041,, 10
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
Posted on May 16, 2010
  • 760 Answers
SOURCE: My very old Craftsman 10"
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Posted on Aug 13, 2010
Testimonial: "Thank you so much, I really appreciate this information and advice."
jyackle5
  • 8197 Answers
SOURCE: I have a craftsman model
Don't have all the answers you want, but may be able to help with the dado question. The 137 generally points to Rexon-Tradesman. A brand sold here by Lowe's.
My table saw is 137.248800 which will Not accept an 8" dado blade set.
You may have purchased the 8" dado set. Try the 6" size, if your saw has a 5/8" arbor. My dado set is the Freud (SD206) carbide version. My saw will accept only up to 1/2", maybe 9/16" dado setup.
The cabinet saws typically use the 8" dado set, capable of up to 3/4".
You should also be able to get the parts that you need at Sears.
Posted on Jan 31, 2011
My craftsman 10 " table saw will run for about a second and then it shuts due to the breaker tripping or the GFCi outlet tripping.
That's saw draws around 15 A while running. Make sure that you have that much to spare on the circuit
May 21, 2017 | Craftsman Saws
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
I plugged in my table saw and everything worked just fine. I unplugged it, and then came back a few minutes later and turned on the table saw again. This time the motor was not running. Power was getting...
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Mar 14, 2011 | Craftsman 10" Table Saw
I have been using my Craftsman 10" Table Saw to
First things first, check the outlet that the saw is plugged into. Does it have power? If so then progress to the saw itself and check the reset button which is usually located on the front panel but sometimes on the back or sides. Press the button firmly to make sure it is not tripped and if it is this will reset it. Make sure the power is turned off and attempt to turn the blade manually ( caution,
the blade is sharp so a pair of gloves is recommended ). If the blade turns with very little resistance then turn the power back on and try the on/off switch. If the saw starts it may very well have been the circuit breaker that had tripped.
Mar 02, 2011 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
May 15, 2010 | Craftsman 10" Table Saw
MANUAL FOR 10" TABLE SAW CRAFTMAN MOD#113298720C
THANKS BUT I WORK IT OUT MYSELF .THE SAW IS WORKING FINE . I PUT IT TOGEATHER MYSELF NO MANUAL. .I AM A YUKONER/BLUENOSER HARRIS C.
Feb 06, 2010 | Craftsman 10" Table Saw
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
I have recently replaced my 29 year old craftsman 10" table saw with a new switch. In trying to turn it on, the motor hummed, slightly oscilated and tripped out the wall breaker. I checked the Sears parts...
You may find a replacement motor on ebay. I deal in Craftsman Belt drive table saws, yours looks to be a direct drive. Sorry I wouldn't be much help with those, Jim
Oct 21, 2009 | Craftsman 10" Table Saw
Half way through cuttig a 2*4 my crAFTSMAN table saw cut out. Hitting the trip switch had no effect. Power source is good. Is there something I'm missing
The trip circuit has a time delay for resetting. Wait about 30 to 60 seconds and it should work when resetting.
Oct 06, 2009 | Craftsman 10" Table Saw
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
Saws Logo
87 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
