Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
I HAVE a17.5 hp briggs and stratton i/c ohv what is the torque specifications for the fiywheel bolt?
5 Suggested Answers
  • 10865 Answers
SOURCE: need head bolt torque for Brigges Stratton 18 Hp
210 to 230 inch pounds. Torque in a crisscross pattern upper left lower right upper right or left or right.
Posted on Jul 10, 2009
mowerman1857
  • 389 Answers
SOURCE: timing for briggs and stratton 15.5 engine
There are no timing marks, timing is correct when the flywheel key is in place, the flywheel is properly torqued and the air gap for the magneto is properly set
Posted on Sep 29, 2009
mickey813
  • 472 Answers
SOURCE: what is torque specifications for briggs and
WELL THAY ALL ARE DIFFRENT SO TELL ME WHAT PART DO YOU NEED IT FOR
Posted on Sep 30, 2009
agent91
  • 2100 Answers
SOURCE: i have a briggs and stratton 14 hp ohv engine on
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Posted on Apr 21, 2010
Tightening sequence for briggs and stratton 17.5 hp engine
tighten bolts opisite of each other snug then one 1/4 turn to tork
Oct 06, 2014 | Briggs AND Stratton Intek Briggs &...
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Torque pattern for Briggs & Stratton 313707 OHV head bolts
its a criss cross patern dont over tight they will break off when running make sure of your tork on them
Jan 03, 2013 | Briggs & Stratton Briggs Stratton...
Torque specs. for a briggs @ stratton 24hp. head bolts
WHAT IS THE VALVE CLEARANCE ON A 23 HP. BRIGS MOTOR AND THE TORQUE ON THE HEAD BOLTS?
Jul 17, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Torque for oil pan on 16 hp vanguard
You should not need torque on those bolts..just need only a few lbs..enough to sets the gasket tightly...I use a small hand wrench and tighten hand tight holding the wrench at the head part of the handle..this will give you plenty of torque without fear of stripping the threads..if you want, re tighten after the engine warms up to operations temp..just a suggestion how I have done it successful many times..good luck..
Apr 26, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Head bolt torque for 16hp horizonal shaft engine
Anywhere from 35 lbs to 220 lbs, depending on the series of your engine. For your engine, the head bolt torque should be 190 lbs.
But I've attached a chart for you to utilize to make sure of your exact engine model series, just in case there was a transposed number, etc.
http://www.small-engines.com/torque.html
Here's the official Briggs & Stratton chart for all versions of their engines, which confirms the 190 lbs torque spec.
http://www4.briggsandstratton.com/miscpdfs/RNT/Engine%20Specifications%20Chart_ms3992.pdf
Hope you found this Very Helpful and best regards!
Aug 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Back firing, load engine noise, engine skip
Could use more info but here are some things u can check--Plug wire grounding to block, old spark plug--check head bolts for correct torque--carb adjustment or jet plugged-governor linkage not hooked up or improper adjustment of governor--if these are good then it could be internal--bad valves and valve adjustment--timing gears
Jul 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
22 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
