Envision 19"lcd monitor
I received an Envision 19" lcd monitor for Christmas 2007. Yesterday, the screen took on a pink hue. Is this the monitor going bad or something else?
  • Glide May 17, 2008
    Having the same problem. Screen has taken on a bright pink hue? Have tried ajustments in settings, doesn't seem to work. Any suggestions?
  • 3 Answers
Could be a problem with the VGA cable. Try using another one. But first you might also like to check your graphic properties. To do this simply right-click your mouse on the desktop, go to graphic properties and make necessary adjustment if or as required.
Newarz
http://visualtreats.googlepages.com/
Posted on May 16, 2008
Envision menu lock
Refer its user manual for details. Try this link to download the manual. Envision L19W698 LCD TV User Manual
Feb 03, 2014 | Envision Monitors L19W698 19 in. LCD TV
My laptop LCD screen is FUBAR and in order to use my computer I have hooked it up to an Envision 19" LCD Monitor. If I start Windows Vista in Normal mode , it does not recognize the Monitor. Pressing...
I would go ahead and boot into safe mode where you say it does work and then take a look. See how it detected it...ie look in device manager and see if it picked it up by it's true brand/type etc. Check the settings both of the display and on the envision itself. Check the resolution selection. It's probably picking it up as a lower res. but when it boots into reg windows may be trying to run at full res and perhaps that's what it won't do. Check to see what driver it's using. It may need the specific driver from envision and not the generic driver. It could also be a bad pin on the envision itself.
If you have another computer you can hook it up to, do that to make sure the envision is working. That way you can deduce which is the problem, the monitor or the setup in your laptop.
Jul 10, 2011 | Envision 19" Widescreen Flat Panel LCD...
Why is my screen a pink hue color
I have one of these and never had a problem like this. The only possibilities that I can think of are a loose connection, possible broken pins, or having the color setup on the monitor configured incorrectly.
Jun 30, 2011 | Envision EN-7100e 17" Flat Panel LCD...
There's a colored bar that comes up on the screen that says "Out of Range" and the images on the screen are all fuzzy and wavy. The monitor is about 2.5 yrs old.
You need to set the PC video output to be at the monitor native resolution, look for the spec of your monitor to find what the resolution should be.
Envision model?
Mar 19, 2010 | Envision 19" Widescreen Flat Panel LCD...
Envision 19" Widescreen Flat-Panel LCD Monitor It just started I have lines that flicker across the screen.How do I stop that it is driving me crazy.
Is there any speaker sets near the monitor or electromagnetic devices near the monitor?
Generally the flicker is caused by some external devices.
Mar 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
ISH819 LCD MONITER WITH TFT?
This link, is to the User Manual for the Envision H 819 TFT LCD monitor,
http://www.technostation.com/user-guide-owners-manual/Envision/Envision++H819+LCD+Monitor
Under the User Manual heading, you will see ->
2009-04-08 12:20:36
To the right of that is -> cache <- in blue. Click on -> cache
The Envision user manual, plainly states that the Envision H 819 monitor, is a TFT monitor.
[18.5" (47.0cm) TFT Color LCD Monitor]
May 17, 2009 | Envision 19" Widescreen Flat Panel TFT LCD...
Envision 19" widescreen
You can go to the Envision customer support website and look for the driver under the driver support section for you model monitor. The website is. www.envisiondisplay.com. You can also call the Envision customer support at this telephone number. !-888-838-6388. They should be able to help you with getting the correct driver to support your set-up. I hope this information helps you with your problem.
Dec 27, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
My envision 19 inch montitor has two stuck pixels
Go to YouTube and search for stuck or dead pixel repairs. They have a few solutions that may help you out. Hope this helps you !
Mar 19, 2008 | Envision EN9410 19" Flat Panel LCD Monitor
Envision en 9110 lcd
More than likely bad inverter board or power boards
Nov 06, 2007 | Envision EN 9110 19" Flat Panel LCD...
Computers & Internet Logo
459 people viewed this question
David Payne
David Payne
