Question about Kenmore 74602 Gas Dryer
Burner no longer will come on
I replaced the ignitor but still dos't work.
  • jerky john May 28, 2008
    dryer would run but not heat up - replaced heating element but still won't heat
Do the two solenoids on the safety valves controls weather the igniter gets voltage. Just curious. Thanks
Posted on May 16, 2008
  • 1,314 Answers
Replace the two selnoids on the safty valves
How long should it take for burner to ignite after turning on oven?
Usually when a oven takes longer then 10 seconds I choose to break out the multimeter and perform an ampere test on the ignitor. An ignitor should draw between as a minimum 3-3.3 amps any less would mean your ignitor was weak and you would replace it. Yes this also means 2.9 that I would replace them as well due to it takes longer each ampere lower for the gas to ignite. If you have any further questions message me back. Thank you
p.s there are two main types of oven ignitors the glow bar type even if it looks like its working you should always test them. Also there is the spark type ignitor as well which usually tend to draw a bit higher then the other kind.
Nov 24, 2011 | GE Kitchen Ranges
The stove top seems to be clicking, but the burner won't light
A common problem with that type of ignitor is that the porcelain insulator (much like a spark plug has) can crack easily. When it does, there will be a clicking sound, but the spark no longer arcs from the top of the ignitor post to the burner and cannot light the gas. Without an intact insulator, the ignitor is effectively shorting out and needs to be replaced.
Dec 27, 2010 | Jenn-Air JGC8536 Gas Cooktop
I have a grill that no longer starts by itself. I have to use a lighter every time. what can I do to solve the problem
There are grill replacement parts out there. You will probably need an ignitor and the burners or maybe just the ignitor if your burners in the bottom of your grill are not too rusty. The ignitor switch probably wore out.
Aug 05, 2010 | Garden
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
Kitchenaid gas oven very slow to start - can be 5 - 10 minutes before I hear it kick on. For a while I could get it to start by turning on a gas burner, but that is 100% effective. Any suggestions? Also...
Replace your ignitor, this is a very common problem. As the ignitor gets older, it gets weaker. When it gets weaker, it usually starts out by not giving good temps in the oven, then it starts to take longer and longer before it lights the oven burner, then it stops lighting the burner completely. A good ignitor heats up fast, allows the current to flow through to the gas valve, opens the gas valve and lights the oven burner within 30 to 50 seconds. When you order your ignitor ask if their is a cheaper generic ignitor for this model. Their can be a huge price difference in some units. You can also have a bad sensor, control board, gas valve, or wiring problem, however for the last 15 or so years every job I have done with your problem has been an ignitor. Good Luck, Appliance Specialists
Jan 26, 2010 | KitchenAid KESC307 Electric Kitchen Range
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
JGSP31GER oven not working - top burners work just fine
Check and or replace the oven glow bar ignitor.
Feb 21, 2009 | GE Kitchen Ranges
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
Ignitors on three burners start when using a burner & dont stop
if you dont have mice that chew and short out wires,you need a new spark moudel
Dec 31, 2008 | Viking VGSC306-4B Gas Kitchen Range
Neff U1420 oven gets hot then cools.
there are is an ignitor nest to the oven burner. that part gets red hot when you turn the oven on, but when starts to go bad it takes longer and longer time to open the safety valve that supplies gas to the burner. or i can turn on but it will not stay on it go es of again. the ignitor needs to be replace.
Dec 08, 2008 | Maytag MER5775Q Electric Kitchen Range
Kenmore 74602 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
