Question about Sharp 29AGM2 29" TV
My Onida 29 Oxygen SMPS is NOT working Horizontal Output Transistor is OK please guide me
2 Suggested Answers
SOURCE: always damage the horizontal output transistor..if
Check the Line Output transformer and associated circuitry.for a short.
Posted on Jan 26, 2010
I hv onida 29 using ic tda9376ps/n3/1733, tda 8359. the problem is the eht is not getting switched on power supply 125 vols is ok.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 10, 2016 | Televison & Video
Onida 29"ctv has width problem. While tuning the fst screen will enlarge...how to solve this fault
Jan 03, 2016 | Televison & Video
Onida igo 20 '' ctv t v 110 voltage one second
Check the horizontal output transistor for collector to emitter leak.
Sep 18, 2014 | Televison & Video
Onida 21''ctv picture coming in stamp type {cutting from four sides}
Hello
Replace its Horizontal output Transistor. If the base-emitter junction has a leak inside it, this type of fault will occur. Before replacing it, check the main DC voltage to LOT [Line Output Transformer]. It should come around 102VDC. If there is not this much voltage, check the electrolytic filter capacitor connected across thie supply line to main negative for open or value developed. Replace the same is good. Till there is low voltage found, check the retifier diode that rectifies this 102 volt DC. If all the above are OK and still you get a stamp like raster, check the heat of the Horizontal Output Transistor described above. if it overheats, LOT is defective and should be replaced with same type and number. OK.
Jun 12, 2011 | JVC Televison & Video
My 36xbr800 blinks six times then pauses then blinks six times, this is repeated......
Check the voltage input to horizontal output transformer [LOT]. Check the voltage at the collector point of the line drive transistor. If the line drive transformer primary gets open this type of fault mau occur. Also check the frequency ant the collector point of line drive transistor and the base point of line output transistor. It should be aroung 15625 Hz.
Check and replace the horizontal output transistor if needy. Replacing it is better. The horizontal output is not working or a short in secondary power supply of SMPS or lot secondary, is your problem
Oct 14, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sharp tv 29" model#29l-fg1l. made from malaysia . the tv standy red light blinking from red to green when press on.nothing yes. what " s be ? please solve my problem?
Dear sir/Madam,
Check power supply(SMPS) section.Check/replace all electrolytic capacitor without power capacitor and resoldaring power supply section after then check horizontal output transistor.
thanking you
uttam
uttam_bm@yahoo.com
Sep 20, 2010 | Sharp Televison & Video
Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Sharp 29AGM2 29" TV Logo
177 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
