Question about Toshiba Satellite (K000004080) Motherboard
Hi all. I have a Toshiba Satellite model no. PSAG8U-04001W When I hit the power button I will get the Toshiba screen and then immediately get a non-blinking cursor at which point the computer is completely frozen. If I hit the power button the computer immediately turns off. I can't boot into safe mode and I can't boot from a CD. I've tried removing the hard drive with no change. I've tried removing the RAM and all that does is kill what video although I now have to hold the power button down for several seconds to turn off the computer. Anyone have any ideas as to what the problem is? Thanks!
  • 148 Answers
SOURCE: toshiba satellite x205-s9800 - Frozen boot screen
try this one
take out the battery and take out the Ac adapter now press and hold the power button for 15 sec this will release any static charge residing in your laptop.
now try start your laptop with battery in.
Further Queries are welcome
Posted on Feb 20, 2009
  • 210 Answers
SOURCE: Black screen w/blinking cursor
So.. you can select safe mode? Or you turn it on and it is resuming into the blank screen?
If the latter. Unplug the power, pull the battery out for 20 seconds or so. Then put it all back together and try booting up.
Posted on Apr 20, 2009
  • 12 Answers
SOURCE: Toshiba Satellite Goes completley off! Black screen, NO POWER!
This problem is likely caused by overheating. The CPU reaches a temp to high and shuts the system down. When you try to turn it on the system is still to hot and it will not let the computer power on. You can try blowing out the fans and heat sink with an air compressor or can of compressed air. If this does not help the problem you may need to have thermal compound reapplied. If that does not fix it it will need a new heatsink/fan/
Posted on May 21, 2009
  • 434 Answers
SOURCE: toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Posted on Jul 10, 2009
  • 32281 Answers
SOURCE: Tecra M3 won't boot, hdd light comes on then off.
The hard disk can be installed in another computer, but it won't boot up and run unless the computer is the same make and model with the same devices as the previous computer.
If it is not then you need to do a fresh Windows install to get a working computer.
What you can do as an alternative is to install the hard drive in an USB hard drive adapter case and use it as an external USB hard drive.
Posted on Jul 31, 2009
I have a toshiba psag8u-04l023 the keyboard lights up but screen wont power on
try the windows key and P to change alternative screen. If not plug in an external monitor if this displays your Screen for the laptop needs replacing.
Sep 27, 2013 | Computers & Internet
I have a Toshiba Satellite model: PSAG8U-04001W, I have no power. I have checked the voltage on the dc side of the ac charger and its fine. there are no status lights and the computer won't turn
This is an obvious board issue if your not getting any lights at all battery blink or HD lights no screen BIOS board is dead, you may want to check to see if power is going from the plug in plastic pin on the board as well the plastic input pin may be solder split or cracked and not connecting.
So the obviously fix for this is take it in to a tech and have them test the board out to see if your getting power to the power button. If your not getting anything showing with even the battery charge indicator and all black out. Board replacement is inevitable, I dislike being the delivery person for the bad news. This does happen...............John
May 14, 2012 | Computers & Internet
Locked keybroad toshiba satellite C660
Try booting in safe mode and see if the keyboard is locked. Maybe the keyboard is bad.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
May 08, 2012 | Toshiba satellite c660
I am trying to figure out how to boot from a usb drive on my toshiba satellite 1415-s105
1. Press F12 key while the Toshiba splash screen is on, this will bring up the boot options menu.
2. Immediately after pressing the power-on button, press the U key.
For more information on boot options for Toshiba:
Jul 21, 2011 | Toshiba Satellite 1415-S105 Notebook
Toshiba Satellite - black screen only when plugged in
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
Jul 07, 2010 | Toshiba Computers & Internet
I have a Toshiba Satellite M60 getting 2 beeps
Check the RAM. If that's not it, you may have a problem with the graphic card.
Dec 06, 2009 | Toshiba Satellite A60 Notebook
Toshiba satellite 1415 S-173 BIOS entry key
Try this...
Toshiba® 335 CDS ESC Toshiba Protege ESC Toshiba Satellite 205 CDS F1 Toshiba Tecra ESC then F1 or F2 Toshiba Notebook [Newer models]
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Nov 04, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba A305 hotkey
Try re installing your operating system (genuine windows xp or vista suggested)
If the problem still persists contact me at
Jul 10, 2009 | Toshiba Satellite A305-S6863 Laptop
Toshiba satellite display problem
ur computer is stuck in resume mode and since there are not all the files on harddrive when it went off so what you need to do is this as soon as it powers on at Toshiba screen keep on taping F8 and then select delete restoration data after that it should boot up fine.
Nov 26, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite (K000004080) Motherboard Logo
689 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
