Question about Kenmore Washing Machines
I have a kenmore washer. Model 110.42822201. Serial CSP3105863. The contols light up, in the front, but when you push start, nothing happens. We replaced the door switch thinking that was it but had no luck.
  • 10,865 Answers
Hi. The problem is with your timer. Replace it and you will be up and running once again. J.
Posted on Sep 14, 2010
Kenmore elite washer troubleshooting
The most common cause of this is the switch that tells when the door is closed. Please post the make and model
May 22, 2013 | Sears Roebuck And Co Kenmore Drain Hose...
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Kenmore front load washer wont start
open the back on the right side on the bottom panel,you well see lots of wires,NOW START tagging wires uses two people for this.it may be easy to change switch out
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Our washer's lights are blinking and nothing is happening? It won't start.
I don't have your specific solution, but I found a lot of manuals for this model washer here:
http://youserguide.org/wiki/Frigidaire_ATF6000E
The one marked wiring diagram is actually a "Washer Tech Data Sheet" that has "Diagnostic tests" quick checks, an error code list, and more importantly, how to read the error codes and the tests to run after getting the error codes. Hope it helps.
Aug 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore 44102 won't start
when you push start button it beeps 3 times door switch is bad what model you have can make difference give me the model no
Feb 27, 2008 | Kenmore 44102 Front Load Washer
Kenmore front load washer won't start. Lights just blink
I had same problem........push options and select button at same time, hold for 5 sec.......choose option.....machine stuck inbetween cycles.
at least it worked for me!
Dec 26, 2007 | Washing Machines
Washing Machines Logo
21 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
