Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429
13.7 cu.ft mdel 970-242520
Just bought this 2 weeks ago. Compressor runs for 7 minutes stops for 15 minutes, the cycle goes on and on. All is level, door is shut tightly. The space it occupies has the factory suggested clearance of 3 inches on all sides and back. Any one know what's up or is this normal?
signed
Electricity ******
  • butch42 May 16, 2008
    temp is fine, very loud though when compressor is on
  • robert samples May 11, 2010
    hows the temps in the unit
 the compressor must be running on overload..or check temperature setting,,,its not normal...
Posted on May 19, 2008
    President:
  • 1,314 Answers
If this is a frost free freezer first make sure all foods in the freezer are behind the edges of the shelf any thing sticking out further than the edges can keep the door from closing properly even though it looks shut also the freezer fans have been known to be noisey we used to have a rule if its loud enough to bother the coustmer its too loud id call and get it checked also run times depend on how many times the door is open
Posted on May 16, 2008
  • 828 Answers
7 minutes on and 15 minutes off sounds like a good cycle time.
After placing my Haier 7 cu. ft. / 198 liter Chest Freezer HCM070LA in a horizontal or tilted position it doesn't want to freeze
If you have run it in a tilted position, the oil has migrated from the compressor to the evaporator. You need a technician to flush the oil back to the compressor. Only run equipment like this on a flat level surface. and always allow to stand a few hours after moving before switching on.
May 01, 2014 | Haier 7 cu. ft. / 198 liter Chest Freezer...
GE Freezer stopped working
Obviously, the compressor is not running. Confirm the presence of power to the compressor itself. If it is getting power and unit does not run, you have an open motor winding OR if you have a start capacitor the latter could be defective. Let's hope that you have the capacitor because they go bad and are a lot cheaper to replace than the compressor!
Jan 19, 2014 | GE 7 cu. ft. Chest Freezer FCM7DR
Kenmore 6.9 cu. ft. chest freezer stopped working
It looks like a bad ignition switch or capacitor. This is not that expensive. Probably not the compressor. Unfortunately, one small part stops the whole show.have a friend who is a tech look at it.
Jan 24, 2013 | Freezers
My freezer is a kenmore mdel #25323725100 , my power went off for about 2 seconds and the alarm will not go off and the quick freeze will not work . HOW CAN I STOP THE BEEPING AFTER 6 HOURS
A Big hammer? or have you tried turning it off at the mains for about 15 - 20 mins then back on again that should reset it.
ThanksTalkAppliance.co.uk
Apr 18, 2012 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Compressor starts and runs for 2 to 3 seconds and kicks off for approximately 1 minute and starts the cycle again.
Please set your thermostat a bit lower. This will keep your compressor longer on/off interval.
Regards
Jan 09, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
It seems that the temp more often goes up to 20-30's and that food is not as frozen when I check it. When temp goes up I check it for next couple of minutes and usually within 10 min the temp is back down...
This is normal. All commercfial freezers must defrost 3 to 5 times a day, or they will freeze over at the coil and then stop freezing. A timer in your freezer turns off the compressor and turns a heating element on for 10 to 15 minutes. During that time the coil heats and melts frost from the coil. Usually within 30 minutes the temperature will briefly rise to 20 t0 25 degrees F and then quickly drop down to 0 degrees F. The food rarely defrosts in this short period of time..
Sep 01, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Temperature at 10 degrees
check condenser fans, if defective or running slow change it
if condenser fan is running, suspect a compressor with internal mechanichal problems, it will run but i can't guarantee how long, maybe a couple of weeks or days. if it's an copelamic compressor, it's going bad.
Apr 21, 2008 | True 49 cu. ft. / 1388 liter Commercial...
Traulsen freezer urns for about 2 weeks then stops getting cold enough
Will it restart again? How old is this freezer? Could be start relay loose or a burned wire connection, worn out compressor. Let us Know what you find
Oct 12, 2007 | Traulsen 7 cu. ft. / 198 liter Commercial...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429 Logo
165 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
