Question about Goodman GMS90703BXA Heater
Goodman 2.5 ton heat pump
The contactors will not stay in. unit will run only if i hold contactors in.
  • 1,420 Answers
Loss of 24 volt power either from thermostat or transformer. Check for voltage across low voltage side of contactor (the small wires).
Posted on May 16, 2008
Will not come on but emergence heat works
Check contactor that operates compressor and condenser fan. Does it try to come on when you first turn it on, or just sits there? If it tries to come on, it could be the capacitor.
Jan 25, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
How to wire high voltage goodman straight a/c package gpc1324 unit with 8kw heat kit
do any one have a old package unit is a goodman i want to see were heater on that package uint or take picture of that unit so i can see where the wire go at the heat
Aug 17, 2012 | Goodman Heating & Cooling
I have a 5 ton 16 seer condensor, the coil freezes up but the coil is clean, i tried adding freeon, but the compressor goes on and off i thought it would be either a low pressure switch or a high...
Compressor sounds out on thermals from being overcharged. Check your airflow across the coil- perhaps a faulty blower or control, restricted duct, or dirty filter could be the culprit to the initial icing. If not, repost with the refrigerant type and pressures.
Sep 26, 2011 | Goodman Heating & Cooling
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman PC060-1B Package AC...Need Wiring Help
Depending on the size of your Electric heat you can use one set of wires because your unit does not run with the heat like the heat pump. The large set of wires going to the electric heat should be used. You may have to jumper a new set to the contactor. On Goodman unit come in L1 and L2 jumper to contactor. Very simple good luck. Rus
Jun 21, 2009 | Goodman Heating & Cooling
Goodman GMS90703BXA Heater Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
