Question about Boss C800 Car Audio Amplifier
I have a Boss Chaos c800 amp. Every time I turn it on it goes to protect mode. How can I solve this problem?
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
  • 4 Answers
SOURCE: wiring up amp/installing amp
Disconnect all the wires and make sure that their all connected to the right terminals. If not positively sure trace all wires back to source. If you ground and power is swapped it will automatically go over to protection mode.
Posted on Apr 05, 2008
SOURCE: the amp turns on but goes to protection mode
Have you checked the REM wire, if it is the wiring may have gotten fried.
Or you may need to get new parts replaced within the amp.
Both issues happened to me.
Posted on Mar 27, 2009
obzy
  • 31 Answers
SOURCE: MY AMP GOES ON PROTECT MODE WHEN I TURN IT ON
Very likely to be a bad earth.
Check the earth connection to the chassis of the vehicle. Remove the screw/bolt and clean around it with a wire brush or wire wool.
May also be a good idea to check for continuity using a multimeter.
Remember to try to have the earth connection as close to the amp as possible, as this will cut down on the risk of a bad earth and will minimise interferance.
Posted on Apr 13, 2009
  • 518 Answers
DID YOU CONNECT THE JACKS FROM THE HEAD UNIT? JUST A THOUGHT AS THIS IS EASY TO OVER LOOK
Posted on Jun 13, 2009
Why am i not getting any sound to the speaers of my boss chaos 2800 watts amp?
Most common problem is cable connection. Wiggle each lead, positive, negative in turn at amp. while playing. I assume you have checked that you haven't inadvertently muted the system.
Mar 18, 2017 | Boss Car Audio & Video
Protective mood
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Hopefully its not toast. .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
Jan 16, 2014 | Car Audio & Video
Serial number for BOSS car amp its a Chaos C700 2
YEAH THATS A DECENT AMPLIFIER AS LONG AS YOUR SUBS DONT REQUIRE ALOT OF POWER YOU SHOULD BE FINE
Feb 12, 2010 | Boss C700 Car Audio Amplifier
My boss amp is on protection mode and it wont work its a 3500 watt chaos idk what is wrong with it
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
Dec 25, 2009 | BOSS AUDIO SYSTEMS Music
AMP STOPPED WORKING. PROTECTION LGHT KICKS ON AT STARTUP & POWER LIGHT KICKS OUT
your ohm load is to low. tell me what kind of subs you have and what size, and what size amp do you have? and how many channels is it?
Oct 21, 2009 | Boss CHAOS CH450 Car Audio Amplifier
Boss chaos 150 200 watt that shows light but doesn't produce sound
May 27, 2009 | Boss C150 Car Audio Amplifier
Auto.resto_0 ---- boss amps...
because the power inlet to the fuse is blown ur amp will not get power, i have the same prob.
just the other way around , i blew the ground..so ugot to get tht power fix then u wil have no problem
Jan 18, 2009 | Boss CHAOS CH450 Car Audio Amplifier
Blown amp, on circuit board, connecting fuse and power connect.
These amplifiers dont employ reverse polarity protection that most higher priced ones do.
The amplifier(s) are definately in need of repair - probably power supply - IF boss sells parts.
Chances are, however, the repair will meet or exceed the cost of a new (appropriately rated) entry level amplifier.
Just about anything can be repaired.... question is, are you willing to pay?
Jan 14, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Dec 05, 2007 | Boss C150 Car Audio Amplifier
Boss C800 Car Audio Amplifier Logo
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
