Question about Dell 968w Printer
Will not turn on. Have adapter plugged in back, still will not turn on.
    Sergeant:
  • 420 Answers
Make sure that there is no any loose contact in the mother board of the printer to which the ac adapter is connected
Posted on Sep 14, 2010
Laptop is turning on and off
Remove the AC adapter (Charger)
PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
Same thing in reverse to plug the AC adapter back in.
AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
You may get away with it for years, and several laptops; and have no problems.
However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
Jus sayin'.
Moving on........
AC adapter removed, remove the Battery.
Press the Power On button in, and hold in for a count of 10 seconds.
Let go.
Do this procedure 2 more times.
(Draining residual power)
Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
Then turn the laptop on, and tell me what happened.
Regards,
joecoolvette
Mar 15, 2013 | HP Pavilion Computers & Internet
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Wii wont turn on
Try this:
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.Reset the AC adapter by following steps below.
Jun 27, 2012 | Nintendo Wii Console
My battery won't charge why not
If it's connected properly, that sounds like a dead battery. Try wrapping it in something waterproof and freezing it overnight. If that doesn't work, replace it.
Apr 06, 2011 | Toshiba Satellite A135-S4527 Notebook
My wii keeps saying a problem has occurred so eject the game and turn the console off and refer to the manual
First turn the Wii console power OFF, and remove the AC adapter's AC plug from the power socket.  Next, check whether the disc is dirty or scratched.  If it is dirty, gently wipe with a soft, damp cloth from the center to the outside.  Wait 5 - 10 minutes.  Then plug the AC adapter's AC plug back into the power socket and turn the console power on.  If the same message still appears, the Wii console may be damaged. turn the Wii console off immediately.  Remove the AC adapter's AC plug from the plug and visit support.nintendo.com for additional troubleshooting or call 1-800-255-3700
Nov 28, 2009 | Nintendo Wii Console
My mom can not turn on here laptop
Hi:
You might want to resubmit your problem, with more details, but some general things to check are:
1) Is the laptop battery charged, or is the laptop plugged in ?
2) Remove the battery, unplug the AC Adapter, then hold the power switch down for 10 seconds, then put the battery back in , connect the AC Adapter and see if it turns on
3) Remove the battery, unplug AC adapter, hold power button down for 10 seconds, and then plug in the AC adapter, see if it turns on.
If all of the above fails to help, You most likely need to take the laptop into a shop for further troubleshooting.
Oct 30, 2009 | Computers & Internet
I accidentally kicked the power plug out of my 360 and now the wireless adapter only stays red and won't connect! is it dead? tried restarting the router and modem but, no luck.
its microsoft!!!!!!!!!! bugs galore!!!!!!!! unplug the wireless adapter while the xbox is off.........turn the xbox back on and let it load with the ethernet plugged in...turn the system off using the control after you have established a connection the the network......unplug the ethernet and reinstall the wireless....turn it back on and let it load.....it still might not work in which case you will have to power cycle one more time.........and oh yeah, check in your setting to make sure wireless adapters are activated...
GOOD LUCK!!!!
Oct 07, 2009 | Microsoft Wireless Network Adapter Xbox...
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell Computers & Internet
Dell truemobile 1300 wireless adapter
Here is a link to dell that will answer your question online.
http://support.dell.com/support/edocs/network/p60542/utility.htm
May 07, 2008 | Dell TrueMobile 1300 802.11g/b Wireless...
Open Questions:
Dell 968w Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
