Question about Canon Pixma MP450 All-In-One InkJet Printer
Keeps showing paper jammed, but no paper in it
    Sergeant:
  • 420 Answers
Just oil the paper feeder and wait for 24 hr. and you can start printing.
Posted on Sep 14, 2010
Alarm light blinking and it keep showing E3,when i want to print,it keep asking me to remove the jammed paper,but i've checked 101 times!! no jammed paper
If the paper out tray is closed or not fully opened, then open it fully.
If that doesn't fix it, then the printer may believe that paper is jammed. You've already checked for jammed paper, so reload the paper supply and press the BLACK or COLOR button.
If that doesn't work, then disconnect the power for a few minutes and reconnect.
If that still doesn't work, there is probably a bad paper sensor or controller board.
Is your printer still under warranty?
Jul 13, 2014 | Canon PIXMA MP190 All-In-One InkJet...
My printer keeps showing the message, " paper jam
Hello Tessty,
The Paper Jam message may appear on the display if the Brother machine is not feeding paper correctly, paper scraps stucked or the paper is not loaded properly in the paper tray, the jam clear cover located in the back of the machine, is not installed properly or the PE Actuator is missing or damaged.
Please visit the link provided below to resolve the issue step by step :
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000095/faq000495_027.html?reg=us&c=ca&lang=en&prod=mfc240c_all&Cat=113
Jun 20, 2011 | Brother Multi-Function Center MFC-240C...
HP Officejet Pro 8500 printer message "Paper jam"
An error code showing that there is paper jam alert, but no paper is in anywhere in the machine except in the tray.....I have checked all areas, taken the back carriage of the unit, opened the top and opened the machine. removed the paper tray, everything, but there is no paper stuck in the unit
Jun 30, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
Message shows 'clear paper jam then press check mark....no paper jammed in printer but it will not reset.
message keeps showing print cartridge cradle cannot move, I have check everything, no paper jams nothing under printer, I am turned off printed but keep getting same message.
Sep 17, 2009 | Lexmark X4530 InkJet Printer
Have a samsung ml2150 which keeps saying paper jam 2 i can see no paper stuck anywhere any ideas please paulmcfc
Inside the printer,there is a sensor which detects the paper.if something is still stuck in between the sensor or some dust is set between the sensor can make the printer feel that paper is still stuck-ed up.
In that case it will keep on showing the paper jam.to solve this issue,you need to open up the printer and clean the sensor assembly gently.once its done it will no more show paper jammed error.
thanks.
Aug 31, 2009 | Office Equipment & Supplies
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
Message shows paper jam even though there is no jam
take all the paper out make sure there is no dirt or dust in the corners,then unplugg the machine for 30 sec. power back up and reload the paper
Feb 26, 2009 | Office Equipment & Supplies
Canon MX300 Paper Jam
I have the same problem - every time I turn on my printer now, the alarm signal shows up with "Paper jam" but when I check for jammed paper, there is none. So I think there's something faulty with the printer. Is there any way to reset it? I've looked everywhere but can't find it.
Jan 16, 2009 | Canon MX300 Office All-In-One Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
247 people viewed this question
old marine
old marine
