Question about Akai PDP4294 42 in. EDTV-Ready Plasma Television
I have a akai pdp4295ed. turn power on and stay on for about 50 seconds an shuts down and green power light on front panel on and off blinks. it also show no signal on screen before shutdown
  • 2 more comments
  • ellascru Sep 14, 2010
    I have checked all capacitors an all appear to be ok . fuse are ok too! can a bad auxiliary power board cause power to shut down?
  • ellascru Sep 15, 2010
    Akai plasma pdp4295ed- When i turn unit on both led on av board come on, after a few second one go out,after that the main power supply shuts down. where can i get a remote for this unit?
  • ellascru Sep 22, 2010
    I replaced power supply. still shuts down.I'm looking at the auxiliary power supply. can you tell me what the output voltage should be on the auxilary board ? I don't have a schmatic for this unit. please help me!!!!
  • ellascru Sep 24, 2010
    I replaced power supply on akai pdp4295ed and power still shut down after startup. there are two green led's on a/d board that lights up on startup. after a few second the led on right goes out and after that the main power supply shuts down. HELP!!!
  • Akai Master
  • 12,061 Answers
This is a fairly classic switchmode power supply problem, I see them often in my shop, the set is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power.
It is my professional recommendation, that you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their, Akai, in your case, their "Local", or a "Head Office", ask them for a referral to an authorised service center. Now, when, at the repair center, you will be able to get the information you want, regarding the repairs, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free.
Whenever a PSU shuts Off automatically, well this is due to the "Protection Circuitry" detecting a Fault, that is potentially so severe that, the set needs to be shut down, then, immediately, to avoid a fire, and explosion or both.
Now it is THIS "Cause" that must be found, and repaired, also any damage done by that "Cause" too.
Now irrespective of whatever the Symptom is , one MUST always start at the Power Supply, and make sure this is 100% correct, as if this isn't NOTHING else can ever be. then once one is sure that it is OK, then work out from there to try and find the actual "Fault". Another thing that is a must have if one wishes to DIY is a service manual.
I have looked but there is scant documentation regarding this model.
Posted on Sep 24, 2010
    President:
  • 2,777 Answers
This is indicative of some major hardware problems in the TV itself. It could be the power board going out, which that blinking usually indicates. If it is still under warranty of extended warranty you are going to want to claim it under that. Otherwise it may be cost prohibitive to repair it, it is unfortunately just easier and probably cheaper / the same price to replace it. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Posted on Sep 15, 2010
  • Akai Master
  • 5,138 Answers
Check power supply board for bad capacitors they will be vented ,swollen or puffed up on top 2200uf 10v 3300uf 10v 1000uf 16v
  • ladywinn
    ladywinn Sep 15, 2010
    OK since you have no bad capacitors replace the Main Board its the board that has tuner and AV jacks on it .Go to this website and type in your model number for list of Parts/Prices
    Encompass Parts Distribution 1-800-638-3328
  • ladywinn
    For hand unit Call Mats Electronics 1-800-628-1118
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You'll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 14, 2010
  • Rylee Smith
    Rylee Smith Sep 15, 2010
    Yes, it can either be the power board or the control board.
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
Screen went black. Shut t.v. off and tried to turn it back on. Power comes on, front light is green, and in about 3 seconds the t.v. shuts off, green light goes off. Was playing dvd at the time. Shut off...
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix. SD TECH
Jul 15, 2011 | Mitsubishi WS-55819 55" Rear Projection...
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
LED Blinking
Okay 2 blinks isnt a error code, so your set isnt shutting down due to a protection issue, so I would suspect one of the low voltage regulator transistors or the horizontal output transistor as being defective
Jul 06, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Akai dlp
i have a similar tv, with 5 blinking red lights on the power off. is that a power board issue? (I see the small green light ionside the tv, flashing green.,,) the outer light stays red or flashed red when i power off. i replaced the fuses, still same issue.
Mar 18, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Will not turn on
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Oct 06, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Akai PDP4294 42 in. EDTV-Ready Plasma Television Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
