Question about Peg Perego Gaucho Rock'in
Gear won't work in reverse and battery won't hold charge
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You have a bad motor, and you need a new battery
Posted on Aug 17, 2017
4 Suggested Answers
  • 156 Answers
SOURCE: no forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Posted on Jul 08, 2010
kirkx
  • 2019 Answers
SOURCE: my 199 plymouth voyager mini
It could be a bad battery, or it could be a bad alternator, ground wire, dirty terminals, etc.
You need to test the components.
Charge the battery.
Then put a voltmeter across it.
It should read 12.5 volts about.
When you crank it, it should drop to about 10.
If it drops lower, the batter or starter is likely bad.
If it does not drop to 10, then the starter or terminals are bad,
If you stop cranking, the battery should come back up.
If it does not, it is bad.
Once started, then you should see over 13.5 when reved up.
If not, the alternator or terminals are bad.
Posted on Nov 10, 2011
Geekman
  • 32281 Answers
SOURCE: sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Posted on Dec 03, 2011
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
Jun 19, 2013 | Acer Computers & Internet
My daughter 2004 Kia won't hold a battery charge.
voltage regulator. it may be in the alternator, or remote mounted. ((the alternator can be charging, but if voltage regulator is'nt working then it won't allow voltage to get back to the battery to keep it charged
Sep 07, 2012 | Cars & Trucks
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
Sony vaio vgn-nr285E battery won't hold a charge
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
It worked for a while and I was able to recharge it, but now it won't hold a charge.
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Sep 01, 2011 | Cell Phones
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
We just picked one up used> it wont "stay in reverse" are you supposed to hold down the gear shift while reversing? Also, how long should it charge for?
yes you have to hold down the shifter to go in reverse, 1 hour for every ah that the battery is, so if its a 12ah battery then charge it for 12 hours
Sep 13, 2010 | Peg Perego John Deere Gator HPX Ride on...
My car was running fine untill about a week ago. My battery started dying alot. I got the battery to hold a charge finally, but now my car is refusing to go into reverse. Its not grinding. Its just feeling...
Sounds like a problem with the gear selector itself. These can wear and cause the problems you describe. Another possibility is that something underneath the car is interfering with the action of the gear selector. I recently had a car with a broken exhaust mount. As a result he exhaust had dropped into a different position and was preventing the free movement of the gear selector underneath the car. All gears could be engaged apart from reverse - so worth investigating.
Jun 21, 2009 | Dodge Nitro Cars & Trucks
Peg Perego Gaucho Rock'in Logo
54 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
