Question about HP Office Equipment & Supplies
Yellow light keeps flashing and it says it is shutting down. I'm unable to print.
    Sergeant:
  • 420 Answers
If the resume button is blinking.. it means that either the paper is over or the top part is opened// either close it or feed papers..
Posted on Sep 14, 2010
I have a ruud achiever 90 plus furnace. The blower motor comes on than I can hear the ingniter click one time and the unit shuts down, 1 green ligt comes on than the other gren light comes on than it...
Check the air filter, if its dirty it will short cycle. A clogged drain will also cause the same problem. There should be a printed legend attached to the inside of the unit or cover that gives you the meaning of all the flashing trouble codes. Perhaps yours may be missing?
Feb 07, 2015 | Ruud Heating & Cooling
The yellow light on the front keeps flashing and it wont print
It helps SO much when you include the Model number of the printer you are asking about. If it happens to be a Dell 1720 then simply push the tab down located at the top right of the output bin. that Tab sticks open can cause the light to flash.
Oct 09, 2011 | Dell Office Equipment & Supplies
I have an HP 1010 laserjet and the red light keeps flashing so I am unable to print and do not know what the problem could be. I have had my printer about 4 or 5 years
Open all doors, remove toner, reinsert toner and shut door. Shut off the printer. Wait.....Turn printer back on.
If red light is still flashing, go to: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00028320#A0 to help identify what it might be. This is an HP site so it is safe.
Sep 09, 2010 | HP LaserJet 1010 Printer
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
Light flashing green and yellow will not print
Hi this is only a try it may work
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 14, 2010 | Canon i850 InkJet Photo Printer
Liftmaster formula 1 garage door opener keeps "bouncing" open
If the door reverses when it hits the floor it is traveling too far. Locate the 'down limit' control on the side of the motor unit and turn this in the opposite direction of the arrow printed on the cover. Some tweaking will most likely be necessary. You can always recognize a sensor problem because the main light will flash 10 times. If the main light isn't flashing it isn't a sensor problem.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Power light flashes and won't let me print - HP3650 no paper jam
Go into your control panel, go to your printer, right click it, then choose "Cancel all print jobs". You may also have to uncheck the "Pause Printing" function.
If all else fails, get the cd. remove the printer and reinstall the software after shutting the printer down and start from scratch just like it was new. If neither of those solve it, go to http://www.hp.com and download your owners manual. There you will find a troubleshooting section that will help walk you through what to do. Hope that helps.
Kevin
Sep 12, 2009 | HP DeskJet 3650 InkJet Printer
My old canon S400 is not printing anything. Trying maintenance checks but still will not print pages. The on off light flashes yellow 8 times follwed by 1 green light flash. What is the problem?
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
All the best Pineworks
May 15, 2009 | Canon S400 InkJet Printer
Canon S400 lite binks 6 times won't print.
1. Turn off printer
Dec 27, 2008 | Canon S400 InkJet Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
235 people viewed this question
Seeker5211
Seeker5211
