Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
My 2wire router modem is connected to a PC w/Windows XP and two printers connected to the PC via USB cables. A laptop running Windows 7 connects to the router via wireless. The printers were set to share and the laptop printed OK to them. Then we went on vacation and upon returning the laptop showed the printers as offline. I have done everything I could find on the web, including restarting everything and running network setup. On the laptop if I try to install a new printer, even if I enter the \\pcname\printername it will not connect. I rebooted the laptop to Windows Vista installed on another partition, with same result. It seems the laptop cannot connect to the PC. I have disabled all the firewalls except for the router's firewall.
One Piece
  • 53 Answers
SOURCE: connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Posted on Apr 14, 2008
SOURCE: Trying to connect Wireless printer
Will it connect without security. Try it out and let me know what you get.
Posted on Aug 06, 2008
kakee
  • 1269 Answers
SOURCE: I need my 2wire password reset
Make sure your computer is hardwired to the 2wire.
Open Internet Explorer
Type http://192.168.1.1
Username and Password = admin
Go to Advance wireless and look for wireless security
You can simply disable it or change the key.
Save or Apply.
Posted on Oct 28, 2008
  • 10 Answers
SOURCE: trying to access my 2wire router
Please try the following:
1. Check the ip address and default gateway on the computer by typing ipconfig in command prompt.
2. Try to ping the default gateway from the hardwired computer.
3. If you are able to ping the default gateway, but not able to log in, Delete Cookies and check if you could log in.
4. If you still could not log in, try from another web browser.
Posted on Apr 01, 2009
  • 28 Answers
SOURCE: Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Posted on Aug 06, 2009
Can I connect a second computer (not a laptop) in my bedroom wirelessly to the 2wire modem that I have connected to my main PC?
Yes, you can. just make sure that the computer has a wireless capability, if not then you need to connect a wireless adapter so you could connect the computer to your 2wire router wirelessly. Another possible way to have it hooked up to your 2wire router is via Ethernet cable but depending on the distance you may need a longer cable.
Oct 10, 2010 | 2wire (1000-000057-000) Modem
Connecting Netgear USB adaptor to 2wire modem
Install the Adapter using the CD, After installing if its windows XP it will ask you to choose XP utility or Netgear utility, choose windows and scan for the network.
If its windows vista , go to start-Connect to - u will see the network name here , try connecting to it
Nov 14, 2009 | 2wire HomePortal® 1800HW Router...
I received a new 2wire 2701HG-B modem router for AT&T DSL (replacing an older 2wire that burned out) and was able to hook up laptops right away no problem, but desktop doesnt recognize new modem how do...
are you on windows XP, Vista, MAC ???
you start out by seeing if you can ping the 2wire. The ip address you ping from a command prompt is the 2wire's gateway, 192.168.1.254
(you can get to the command prompt by clicking start, then click run, and type cmd and click ok on windows XP)
(on vista, you just click start and type cmd right above it where it says start search and hit enter on your keyboard)
(MAC's have a ping utility located by clicking on the harddrive, applications, network, network utility, and then the ping tab)
a little black window pops open, thats your command prompt
type ping 192.168.1.254 and hit enter on your keyboard
if you dont get replies, then your computer doesn't see the 2wire.
call tech support at 877-722-3755 24/7 for further support if required. We can make sure you nic is config properly, working properly, your not being blocked by a firewall, etc.
Sep 13, 2009 | 2wire 2700HG-B Router (2700HGB)
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
I need drivers for Vista
hi
plz go thru the link below
http://www.nodevice.com/driver/company/2wire.html
and check it whether it is a trusted site and then u can scan it for your virus. u can even consult with ur comp vendor for its security
thanx and regards
sukhiii
Jul 25, 2009 | 2wire 1000hg DSL Modem & 802.11g Wireless...
I have a desktop connected to a ICONNECT ACCESS621 ADSL 2/2+ ROUTER, how do I connect my laptop to the same modem?
The 2+2 means: Combo feature, means 2 computers can connect and access internet at the same time ( one via USB and the other via Network Port) So connect one with a network cable and the other with a usb cable.
Feb 09, 2009 | 2wire (1000-400108-001) Router
DNS error when connecting PS3 to internet
you could try getting a wifi adapter and creating an access point, you can connect that way if your ps3 has wifi I have a laptop with windows XP Pro and have been trying that my desktop PC with Vista Home can see it.
MY Components:
-Desktop PC with Vista Home (Main PC, connected to Internet with Ethernet to a Linksys Wireless Router B and G).
-Get internet thru cable TV (broadband),from this cable modem plugs to router and from router to PC Vista(desktop)
-Linksys Wireless G/B Router
-G-Card for my Laptop Windows XP Pro and
-Playstation 3 capable of sharing info and use printer
At the moment all of them have internet w different IP's (000.000.0.001, 000.000.0.002,etc.). What I want to achieve is that I can use the Printer that is connected via USB to my PC Vista (desktop) and share files. Right now the only thing been able to do is that my PC Vista see my Laptop but Can't find my PC on my laptop. Anybody, Help?
-When I turn On my media sharing in my PS3, my internet on Laptop loses it while PS3 search and find,then, because laptop lost wireless,the PS3 looses the laptop and I get wireless back. I knowis a stupid setting but tired of workin back n forth. Thanks
Jan 10, 2009 | Sony Playstation 3 (PS3) Console
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire dropping xp pc
hello!
you may try this and see if this help solve your problem
Step 1try to connect your computer directly to the modem and check if you will also experience problem
Step 2: Shutdown the computer.
Step 3: reset the router while power on then Unplug the router’s power cable.
Step 4: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 5: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 6: Plug in the router's power cable once the modem’s lights appear stable.
Step 7: Power on the computer on and configure router settings if neede
Step 8:test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
May 01, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
Computers & Internet Logo
26 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
