Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
  • Bosch Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 21, 2010
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
Mar 27, 2013 | Bosch Classixx WVF 2402 Front Load...
When The door is open continues to run on my Bosch Axxis Clithes Dryer WTA3510US
the door switch contacts are welded together,normally it switches when the door is opened to light the interior drumm light and to the dryer circuit when the door is closed,but these contacts cant due to being stuck
Nov 15, 2012 | Bosch Axxis WTA 3510 Electric Dryer
DRYER WONT START
Most modelsof Bosch dryers has a reset thermal fuse. Look in the back of the dryer for a little red button. Our check your user manual for the location.
http://www.on-timeappliance.com/dryerrepair.html
Mar 27, 2012 | Bosch Dryers
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Power is on, lights are on, put it to a setting and hit start and nothing happens no water(water is on) no spinning and no drying. Have checked all the hoses and cleaned the filter.
I sometimes get this happeing if the door doesn't close and seal. If you can open the door then this is the issue. THe door should seal and won't open when you hit start. Try opening and closing the door tightly
Feb 28, 2010 | EuroTech EWC177 Front Load Washer / Dryer
Dryer wont start,
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Kenmore dryer does not turon on
CHECK THE FOLLOWING---
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer/control
May 31, 2009 | Kenmore Dryers
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
362 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
