Question about 3M X45 Multimedia Projector
I am unable to reset the filter timer because i lost the remote, can this be done without the remote.
Use the projector's menu to go into 'Advanced Menu Settings'. Go down to 'OPTIONS' sub-menu, go right then down to highlight the "Filter Time". Press and hold the arrow to the right for 3s to bring up a popup to reset the filter time; preset the up arrow to reset the filter time to 0h.
Posted on Sep 21, 2010
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
How do you unable an ipad without conneting to itunes
You could do it remotely using 'Find My iPad'. From the iPad itself, you could reset all settings and erase all content and settings, which can be done under 'Settings', 'General', 'Reset'.
Aug 14, 2014 | Apple iPad Tablets & eReaders
Lost remote for projector VT540 and need to reset lamp
only by using the remote to reset the timer
Press and hold the OFF button on the remote panel, for 10 seconds
Mar 27, 2013 | NEC MultiSync VT540 Multimedia Projector
Can I reset lamp timer without remote. Lost remote
It cannot be done without the original remote---they are not that expensive--Google the model number with "remote" and do not bother with a universal remote.
May 27, 2012 | Panasonic PT-56DLX75 56" HDTV
How do I reset the filter timer to 0 on a Dukane ImagePro 8711?
How can i enable the projector keypad which has been disabled and the remote control has been lost?
Apr 08, 2011 | Office Equipment & Supplies
Unable to reset lamp life notification
Try it, press and hold Volume Down on TV front and 0 (zero) button on Remote at same time for 5~6 seconds to reset lamp timer.
Thanks.
Sep 13, 2009 | Panasonic PT-40LC12 40" Rear Projection...
How do I reset the filter timer on the hitachi cp s210?
The reset function is in the options menu. Once you scroll through the menu locate the filter timer, forward to the timer locate reset, you then need to hold down the reset button on the bottom RH of the remote control.
May 07, 2009 | Hitachi CP-S210 Multimedia Projector
Panasonic PT-60LCX64 Air Filter Cleaning
Cleaning filter for the Panansonic PT-501LCX64.
I just had a T.V. tech do this. The filters are located on the two removable filters on the back side of the T.V. They look like the speaker units. He removed those two units, unplugged them & set them on the floor. He took some type of electronic cleaner with a cloth & wiped them down. The filters themselves are plastic. He explained that air flows through some tube connected to these plastic filters for cooling down below. He admitted they didn't look dirty--put everything back together & it is working fine now.
I imagine that dirty or not the timer is automatically set for every 400 hrs. of use to give you the prompt that the filter needs cleaning & will shut off in one minute so you can call a T.V. tech?
So to reset the timer--follow the other detailed prompts listed on this board & or use your owners manual & follow the prompts for replacing the bulb. That should take you somewhere to reset the timer--so you have another 400 hours of operation.
I believe it's with the T.V. turned off--hold down the down volume on your tv itself while holding the swap button on the remote control for 5-7 seconds---then follow the prompts. You should see a prompt for replacing a bulb & then one for filter cleaning. Then just reset the timer.
Hopefully this will help?
Nov 04, 2008 | Panasonic PT-60LCX64 Television
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
Resetting the air filter timer
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Dec 12, 2007 | Hitachi Office Equipment & Supplies
3M X45 Multimedia Projector Logo
303 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
