Question about RCA R52WM24 52" HDTV Projection Television
Power light comes on then goes right off in 2sec
    President:
  • 2,777 Answers
Sounds like a failed power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Sep 14, 2010
  • 2 more comments
  • ronmar53 Oct 06, 2010
    bull ****! you can fix it i did, it took me about hour this what you do remove the back panel look on the left hand side on the bottom board towards the top there is a metal u shape looking shield in the center of that shield you will find a (cap) capacitor run your finger across the top of it if it is beveled or not smooth that's your answer and your problem just pull the trey forward lift it up and find the number of the cap on the bottom of the board go to walmart and get you a cheap electrical soldering stick and some electrical solder cost you around 5 dollars remove the cap the number on the cap is 16v 2200uf 105 degrees radio shack doesn't keep them so just on google type in the description of the cap and there is about hundred company's selling it cost between $1.50 to about $2.00 .
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Good job! Thanks for the info.
  • mandragon_hu
    mandragon_hu Aug 04, 2012
    Where can I get the schematics for this TV??? I have the same Power Problem but the cap reading are fine. Some where a long the line I'm losing my power signal. I did not see any short or burn parts and all resistors omh right...
  • mandragon_hu
    So, where can I get a copy of the schematics for this t.v. I have the same problem but cap reading is ok, there's no burn parts or shorts and all resistor ohm fine...
My dryer will only stay on for about 2sec and then stut off if you wait you can turn it on but again it will not stay on longer then 2 secs. And the light is on when u open the door so there is power and...
CHECK THE PUSH START BUTTON WITH A MULTIMETER. TRY STARTING IT WHILE PUSHING THE START KNOB AND HOLDING IT IN? WHAT HAPPENS? STAYS RUNNING? OR GOES OFF? THE LITES ONLY USE VERY SMALL WATTS SO IF U HAVE A BAD POWER TERMINAL WHERE THE POWER CORD GOES INTO , IT MAY BE AN ISSUE AS WELL CHECK FOR PROPER VOLTAGE AT TERMINAL AND HOUSE OUTLET, LASTLY AND HOPEFULLY NOT UR MOTOR MAY BE ON THE BLINK
Feb 28, 2015 | Dryers
Visco vsc20v1 will not powers on and right back off
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 22, 2013 | Element Electronics FLX3711B 37 in. LCD TV
Nokia n96i dual sim goes off after 2sec from power on.
It sounds like its sim locked. Which carrier did you buy it from? Put in a sim from the carrier you bought it from and see if that fixes it.
Sep 07, 2009 | Nokia N95 Cellular Phone
Switching on the laptop
try to take it out from power and take the battery out for 15 minutes.
Mar 28, 2009 | Computers & Internet
The tv goes on for 1-2 seconds then goes right to stand by
i turn my tv on and all of a sudden it goes off then on then off and keeps doing it will stay off for 2sec goes on for 2sec
Jan 01, 2009 | Televison & Video
Blue amp light lights for 2sec
bad head unit or look at your ground wire good luck
May 24, 2008 | Car Audio & Video
There may be more than one problem. The fact that the radio AND the amp are seeing a voltage of 7v indicates that the battery is weak or there is a bad connection somewhere in the power line.
It's also possible that the amp is defective (shorted output transistors?) and when it turns on, it's drawing excessive current. That would cause the voltage to drop more than normal. If the amp is drawing excessive current AND there is a bad connection in the power line, the amp may begin to blow fuses (depending on the reaction time of the protection circuit) when you repair the power line problem.
Apr 25, 2008 | Sony XM-1252GTR Car Audio Amplifier
Sony LCD HS73 LCD goes blank 2sec.
defective backlight inverter unit. Replace the inverter unit or chek if there is any dry joints inside the unit.
Apr 02, 2008 | Sony SDM-HS73P 17" LCD Monitor
RCA R52WM24 52" HDTV Projection Television Logo
553 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
