Question about SanDisk Sansa m240 MP3 Player
Songs deletion I deleted songs off of the player, the songs disappeared off of windows but it still the memory is full and you check on the player and the songs are gone but it says the internal memory is full
  • 8,596 Answers
Needs to be reformatted
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
When downloading songs, if I change cds the mp3 deletes the last songs I put on. Why???
It will normally delete a song when the player is full of songs, as you add new songs it will delete the old songs...
Check your player to see if it is full.
Mar 11, 2010 | Philips GOGEAR SA6045 MP3 Player
Hello, Am using Sansa c200 . am unable to delete songs which i hav copied into player. and even i cant see any songs on computer(my music folder was showing empty) .i even tried to format the disk ..but...
See this tip posted here on this site. It may explain what is going on. copy this address into a new window -- http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
If that does not work go here and download the Sandisk utility. http://kb.sandisk.com/app/answers/detail/a_id/156
Jan 16, 2010 | SanDisk Sansa c200 MP3 Player
Rca rd2025a cant delete songs
try reloading the firmware and that will erase all the songs on it and might fix the problem of it not deleting the songs
Sep 28, 2009 | RCA Lyra RD2052 MP3 Player
Deleting files from mp3 player
if its is a Flash-based MP3 player. That means that it has a small amount of built-in memory inside the player as well as an SD expansion slot for storing songs. When the player is connected, songs may be stored in either of these two places.
you probably stored your songs on the internal memory. In either case, there are two basic ways to delete songs off of your player. You can use MP3 software (such as MusicMatch) to do this or just do it by GA_googleFillSlot("TL-IMU-Article"); q.gifhand.
To delete the files, follow the same process but delete the files instead of adding them. Assuming that you are using Microsoft Windows, click on "My Computer" and find the drive that is labeled "Removable Disk" and click on it. Look for a songs folder and continue to drill down folder by folder until you see your songs show up in the list. Highlight the songs that you want to delete (or the whole folder) and hit the delete button on your computer.and it will delete.hope this helps
Sep 15, 2009 | Audio Players & Recorders
My sansa e260 shows full memory in its screen
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files - you can delete at will.
Or:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 17, 2009 | SanDisk Sansa e260 MP3 Player
Mp3 sansa sandisk - deleted songs
Try formatting the drive. Plug it in. Open Windows Explorer. Right click on the drive and select format. This will delete all content off the player.
Aug 31, 2008 | SanDisk Sansa c140 MP3 Player
I can't delete the songs and the computer says my mp3 is "full"
You need to be in MSC mode to do deletion in My Computer; put in MSC mode in the settings menu under USB, then plug in, go to My Computer and open it as a drive, go to Music folder and delete by rightclicking on songs and choosing delete. You can also format the player by rightclicking on the drive letter of the sansa and choosing format. If you are deleting from a program like Rhapsody (ugh) or windows media player, you will get a lot of issues and not all will delete. Stick with My Computer in MSC. Also as a side note, make sure you have all file folders showing including hidden files in the tools menu in My Computer
Oct 19, 2007 | SanDisk Sansa m240 MP3 Player
Cant Delete
well putting songs on your MP3 player is easy its taking them off thats the problem, so here are some easy steps to doing so. 1. plug in your MP3 player to the computer (USB) 2. go to my documents 3. scroll down to other 4. click sansa m230 5. click TCNANDO 6. then you have an option of Albums, Music,and RECORD click on Music 7. then you have the artists names and all you have to do is click the artist, then the album, and the ones you dont want you right click it and select delete 8. repet that until done deleteing songs of your choice 9. now you can add songs
May 29, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
