I have a new automatic washing machine purchased 3 month back.Machine is not even starting and there is no drainage of water from the machine.
  • Washing Mach... Master
  • 17,130 Answers
If new do not loose your waranty which is your priviledge by tampering. So call your dealership immediately and register the complaint. If not log on to the support site of the make and register.
The fault can be the drain valve, pump or the control board. So get support.
Posted on Sep 14, 2010
Water is not draining or pumped out why ?
Do you have an HE or standard washing machine?
If its not draining on an HE machine you need to check the drainage port on it which is usually on the lower left hand side facing it. Beware there is water that will come out especially if there is water in the machine. There is probably a sock or some other items trapped in there making the drainage slow. The drainage filter on a standard machine varies depending on the brand. Usually they are on the back of your washing machine. I would check the drainage hose and the filter to see if there is any socks or other items stuck in them. That is usually the issue when the water isn't spinning out. Good luck
Nov 21, 2014 | Washing Machines
Baumatic 1206.1 washing machine drainage issue
you probably turned it off before the empty cycle had finished
Jan 22, 2018 | Baumatic Washing Machines
New dishwasher won't wash
What noise does it make?
Jun 09, 2013 | Dishwashers
The screen is flashing F3, what does this mean?
the drain pump of the washing machine is either got loose or its not working or the drain pump is blocked. Water outlet fault (Grey Hose) If F3 is flashing in the display, there is a problem with drainage. Check: • that no objects are stuck in the drainage hose outlet. • that the drainage pump is not blocked by foreign objects. Clean the pump (see the "CLEAN THE PUMP" chapter MENTIONED BELOW FOR MORE HELP). • that there are no kinks in the drainage hose. ------------------ CLEAN THE PUMP Checking the trap and drainage pump The washing machine has a trap, where coins, hairpins and the like can get caught. To clean the filter and drainage pump: 1. Make sure the machine is empty of water and that it is switched off at the mains. 2. Open the hatch for the drainage pump as shown in the illustration. 3. Drain out the water, into a bowl, for example, by unhooking the drainage hose from the pin inside the hatch. 4. Unscrew the cover anti-clockwise and remove. 5. Remove any foreign objects from the trap and pump assembly. Check to see that the pump blades, right at the back, will rotate. 6. Screw on the cover, replace the drainage hose on the hatch pin and close the hatch.
---------- This will help.please do rate the solution if helped.keep updated for further assistance.
Apr 29, 2010 | Asko W6021 Front Load Washer
MACHINE MAKES DOES NOT WASH,WATER OUT FROM DRAINAGE PIPE
is it a top or front loader?is your drain hose same level as top of machine?if not ,raise hose to level and start cycle.machine will not wash if it does not fill.please reply if u need more help
Apr 05, 2010 | LG Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Intermittent water observed under machine
Difficult if not seen. Most common water on the floor senario is a drain pump leaking:or a perrished pipe from friction.or sometimes, water backs up from the house drainage system due to a restriction.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Washing machine is leaking from the bottom
try looking at the tubes where the filter is. remove the front cover at the bottom and check the filter. worth a shot
Nov 13, 2007 | Samsung WF203ANW Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
