Question about NRS Hoveround MPV 5 - Used Power Wheelchair
How to engage drive for wheel - NRS Hoveround MPV 5 - Used Power Wheelchair
  • 692 Answers
Albet There are two levers in front of the chair ahead of the batteries In one position you are in Drive and in the other Freewheel. Make sure that both levers are in the same position depending on what you want to do Hope this helps you
Posted on Sep 14, 2010
2007 Dodge Ram 1500 hemi my 4 wheel drive does not engage after turning the switch to 4 wheel high or low I hear clicking under vehicle but does not engage
Remove the actuator motor assembly from the transfer case and try to manually engage the transfer case, if it is easy to engage then the actuator is the problem.
Jan 09, 2017 | Dodge Cars & Trucks
Not a problem as much as an answer. Are both wheels rear wheels engaged at all times on my 4x4 87 ranger?
this is a rear wheel drive vehicle and as such the rear wheels are always engaged.when in 4 wheel drive the transfer case in gages and the front differential connects and is engaged.unless the 4 wheel drive is engaged the transfer case just free wheels.
Apr 27, 2011 | 1987 Ford Ranger
08 f150 4x4 on front end only one side is disengaging when in 2 wheel drive. The problem is when engaged into 4x4 wheel drive the front drive line spins and both sides engage but only the back wheels spin...
If I read this correctly ( which I might not have, bit early for me ), the front drive shaft will engage ( from the transfer case ) but the front wheels are not engaged ?
If so, sounds like either the vacuum from the IWE ( Integrated Wheel End ) is not being released, or the IWEs have had an issue with part vacuum ( damage vacuum lines ) and the IWE gear is rounded off.
If you pull the vacuum lines at the IWEs ( there are 2 lines, 1 is the vacuum line, the other is the vent tube that routes up into the engine compartment and is not attached to anything ), the front wheel should engage ( might need a 5 * turn to mesh the gears ). With the vacuum lines off, jack up the front axle ( take precautions, chock the rear wheels, parking brake, jack stands, etc ) see if the front wheels are engaged ( turning one wheel should turn the other ). The option is to do this after the truck has sat over night, and the vacuum has been released out of the vacuum reservoir.
If the wheels turn correctly ( engaged ) I would think the contact plates in the transfer case are not making contact. Good starting point for this is the connector on the side of the transfer case, some times this gets gummed up, and the pins do not make good contact. The contact plates in the transfer case are used for a few things, one of them is to signal the IWE solenoids to release vacuum to the IWEs.
Operationally vacuum holds the IWE ( Integrated Wheel Ends ) out, and once vacuum is removed the spring engages the IWE.
Here is a black diagram of the IWE vacuum system
Feb 05, 2011 | 2004 Ford F150
My 4 wheel drive is not engaging. My transfer
The internal lockouts are not engaging so they need to be replaced
Apr 11, 2010 | 2001 Chevrolet S-10
4 wheel drive wont engage on kia sportage 2001
there are vacum line one on each side behide the wheels see if they are broke or leaking i had the same problem
Feb 10, 2010 | 2000 Kia Sportage
While driving, four wheel drive quit working. It
Check the fuse for the four wheel drive before taking another step,it is electrically engage,hope that help you and clear your mind
Jan 17, 2010 | 2001 Ford F250 Super Duty Super Cab
When i engage four wheel drive from the lever in the car i only get traction on the rear wheels. Is there a diff lock i need to engage
It depends, look at the hubs on your front wheels? Is there a knob in the center of the wheels? If so, then turn this knob to the right and you will have engaged the 4 wheel drive? If you do this, however, make sure you engage the 4 wheel drive inside the truck (if your truck has a 4 wheel drive gear shifter).
Oh other Rangers you have a knob on the inside of the cab it should be somewhere on the dash. You can turn it to the right and this will engage the 4 wheel drive.
Finally, when you engage the 4WD make sure the engine is cut off so it doesn't mess up your transfer case.
Jan 08, 2010 | 2000 Kia Sportage
I have a 1997 5.7 Liter Cheverolet Z71. The 4 wheel drive is not engaging. I can hear the trasfer case engage and can even hear the difference in the transmission when in 4 Lo/hi when driving. However...
Having 4 wheel drive is not actually the case unless you have limited slip on both axles. Do you know if one wheel will spin on both axles. If you can't get either wheel to spin on the front axle and one will spin on the rear then I would agree your not getting front wheel drive. Since you can tell a difference between hi/lo the transfer case is definitely engaging
Dec 25, 2009 | Chevrolet Silverado 1500 Cars & Trucks
NRS Hoveround MPV 5 - Used Power Wheelchair Logo
Top NRS Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Are you a NRS Health and Beauty Expert? Answer questions, earn points and help others
