Question about Polaroid TLA-01511C 15 in. LCD Television
Why , does it not work as a pc monitor when it should, as it is hooked up correctly?
    President:
  • 635 Answers
You have to manually select the VGA option when you press input from the remote. It will not automatically do this for you.
The input button should be located between the volume and channel buttons on your remote.
Posted on Sep 14, 2010
Emachine el 1852g-52w motherboard
the problem,maybe the PSU the computer might not get enogh power.or you can allways clear CMOS and se if that helps.
Jun 22, 2013 | Computers & Internet
I just got this eMachine E15Tr monitor and am trying to hook it up to my current pc. They are both hooked up correctly to my knowledge but whenever I turn on my pc the monitor waits to turn on. When it...
You have three components which could be faulty: Computer, cable and monitor. Replace them one by one until you find out which one is giving you trouble:
  1. Hook up a portable computer to the monitor, using the same cable
  2. Same thing, only with a friend's cable that is known to work
  3. Try using the cable to hook up a friend's computer and monitor
  4. Take your monitor to your friend's house and see whether it works there
  5. Try using any other source of image, check the back of your monitor to learn what else you can plug, other than a computer
Each combination you try will give you more information, until you have enough data to isolate the problem. It *could* be that your computer's resolution is not supported by the monitor, but I doubt it.
Feb 26, 2013 | Computers & Internet
I hook up my computer and monitor all correctly but i get no video
lets first check weather the vga cable is properly attached to the port.if ok, and still no video the fastest way is to hooked up your pc to the other monitor just to ensure if monitor issue. by the way does your pc has power indicator how about the fan in the power supply does it work?,you have to considered those things to isolate where the main cause came from.
Oct 01, 2012 | Gateway GT5412 (232587) PC Desktop
Why the monitor says "no
because it doesn't receives any signal from the pc - check the video cable. If the cable is correctly plugged in at both ends then the pc is defective - test it starting with the video card.
Jul 01, 2011 | Dell E176FPC Monitor
When i turn on the monitor its shows analog and then the screen goes blank but the power is still on what do i do? take note i think i need it to go back to the digital state its a viewSonic VG710s
First I would make sure the video out on your PC is working correctly. The best way to do this is by hooking your PC up to a different monitor to see if the second monitor operates correctly. If it does not then possibly you may have an issue with your video card. If you are interfacing to a laptop, make certain that you have the video out configured to output to an external monitor. This can be achieved through your computers control panel.
I also had a similar issue with one of my ViewSonic monitors and resolved it by completely unplugging the monitor from my PC and also for the electrical outlet. I let it sit for 5 or 10 minutes, hooked everything back up, restarted the computer and it corrected itself.
Hope this helps
Codebynite
May 01, 2011 | ViewSonic VA712 17 inch LCD Monitor
I hooked up my PC to my LG 50 in. HD 1050P to use it as a large PC monitor nothing happens, my Pc is an IBM NetVista do I need software to activate?
if your PC works with a standard monitor, just make sure you select the correct input on your TV. No special software needed.
Dec 27, 2010 | IBM NetVista PC Desktop
Trying to hook up compaq presario 5000 desktop, monitor is not working correctly, it works with the old Gateway computer, so I know the monitor and cable are good
check to see if you have two ports in the back of your desktop, try the other one if you do. If not, there is most likely a loose connection.
Mar 18, 2010 | Compaq Presario 5000 PC Desktop
Only black and white on fujitsu 42" monitor with s-video
You need to check the Format, either NTSC or PAL, USA = NTSC, Europe etc, PAL. Set this correctly.
Mar 05, 2010 | Fujitsu Plasmavision 42" TV
Cant get monitor to work with my acer
You need to have the correct drivers for these monitors installed on the acer. You can boot in Safe Mode (Hit F8 key at boot-up) and the monitor should work. If that doesn't work, your video card may be shot.
May 02, 2009 | Computers & Internet
Interna speaker not working
It is hooked up correctly. just have no volume even when its turned up. check for speker open or loose wire or broken wire. check sound section in monitor.
Aug 30, 2007 | LG M1717S-SN Monitor
Polaroid TLA-01511C 15 in. LCD Television Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
