My tv went off for good during power outages, tried to put it on not responding, the power button rights red, please help.
    President:
  • 2,777 Answers
Sounds like a failed power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You will need to contact a local TV repair person in your area. If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
So sorry that I don't have better news but it is definitely a power issue internally.
Thanks
Tim
Posted on Sep 14, 2010
Testimonial: "Thank you, we say "Asante sana" you help much, can i possibly ask for the new power supply so i can change it, cause my local technician not that good"
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
Power outage
It sounds that the main system control memory IC data has been currupted.
Sep 26, 2013 | RCA L32HD31 32 in. LCD HDTV
This morning our electric went off and since its been back on our tv is not working properly. when you switch it on all we get is a blue screen which changes to green and orange intermitently. none of the...
It is possible that the intermittent power outage may have resulted in failure of the sensitive input/tuner/AV controller section. It might turns out to be a damage in one of the functional IC's and so it may not be easy to do it yourself. I would like you to switch off the set - power off for some hours and try again so as to reset. If not get help to probe into the Microprocessor, check if the X'tal Oscillators are working, possible there is an errror in this section. Hope it works out cheaper than expected but get a quote for your work and get only experienced personnel to help. Good day
Aug 02, 2010 | Televison & Video
After a power outage, my wii will not turn on
You can try a new AC adapter.If that does not work,it will need to be repaired by a Nintendo authorized center.(I used to work at one).If you do by a new one PLEASE buy Nintendo brand.The "off" brands usually end up in some kind of problem down the road.
Good luck and agme on!
Jul 12, 2010 | Nintendo Wii Console
Need operating manual
if you are asking about the ” innovage” large tv remote… you do not need a code booklet.
maunally turn your tv on
point the remote at the tv
push ” code search”
a red button will blink
push the ” TV” button
then push the upper right botton with a circle and line on it…
the red burron will blink during each push…
at some point the tv will turn off…
push the “enter” button
the tv will then work with the remote.
it it takes too long to catch so to speak…
do not turn the TV off…
during the process… go ahead and push search code again..then TV
then on/off botton sometimes this speeds up the process.
i’ve found every once in a while the large remote stops responding to the on/off button…
just repeat the steps.
We hope this helps please rate/vote for me if it does thanks
May 09, 2009 | Televison & Video
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Whirlpool Duet Sportwon't respond after power outage
IF YOUR MACHINE IS A WHIRLPOOL DUET TRY THIS ;
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Good luck
Jun 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kd-32fs170
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 24, 2007 | Sony KD-32FS170 32" TV
Progressive power up problem
Yeppers. Sounds like the standby power supply has a bad capacitor in it and the regulator Ic is defective. These parts should only be replaced by quilified technician as there is very high voltage inside these sets. Good Luck
Jun 14, 2006 | JVC AV-K29MX1U 29" TV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
