Question about Bunn CWT 15-3 (3 Lower Warmers) Coffee Maker
How do you perform a descaling to a Bunn CWTF15 3LWR
    Sergeant:
    Novelist:
  • 193 Answers
The CWT 15-3 has a water tank that can be filled by a water line attached to the machine or by removing the thumb screw on top of the machine near the front. The screw holds a small cover about 2 by 6 inches that lifts off. You can use this to pour water in if you don't have a waterline hookup. This is the tank opening into which you will pout a quart of vinegar to descale the machine. Also this machine has a long thin spring with it from the factory. If you remove the brew funnel, then unscrew the sprayhead above the brew funnel, you can descale the tube that carries hot water from the tank to the brew funnel. Just snake the spring into the tube where you unscrewed the spray head, and slide it in and out until you no longer see scale on the spring. When you pour a quart of vinegar into the machine let it sit for 20 to 30 minutes and then flush with 3 or 4 carafes of water. This should remove the scale from the tank. In areas with hard water and high usage of the machine, one cycle of vinager may not be sufficient to totally remove all the scale. Repeat as necessary until the water is clear.
Posted on Sep 14, 2010
How do I descale my keurig?
some people use white or distilled vinegar and run it thru the unit . I have even seen descaling fluid sold in stores but have never needed to do anything on my BUNN coffee maker
Feb 06, 2017 | Coffee Makers & Espresso Machines
My hot water spigot no longer works. Is this caused by a build-up of sediment from our years of heavy use, or it is time to upgrade?
It sounds like this is a constant use item, and you do not have the time to descale it. If you have the time, you may want to try to descale the sediment using citric acid or white vinegar. This will dissolve the scale, and after awhile you could soon get water through the spout. Here is a link to the manual:
http://www.bunn.com/sites/default/files/discontinued_manuals/35582.0000.pdf
Apr 17, 2015 | Bunn CDBC 35 Coffee Maker
Hi I have used descaler twice and now it wont work descale or anything at all have had the coffee maker two years. Is that the life span of them. I am disgusted as I paid a lot of money.
I have had a Bunn machine for 9 years now, and still go'n strong, I know this desn't help your issue, but your next purchase might should be a Bunn
Oct 22, 2013 | Coffee Makers & Espresso Machines
How to descale Bunn CW15-APS coffee maker
delime the sprayhead and reservoir drain (in the top) with a deliming spring or a screwdriver. to delime the tank, put a half gallon of vinegar in the top and catch the hot water as it comes out of the sprayhead. leave it sit for about 20 minutes and brew at least 8 times (w/o coffee) or until you can no longer taste vinegar
Jun 20, 2012 | Bunn CWTF Coffee Makers & Espresso...
How to repair a bunn commercial coffee maker
Hello, I thought I would help you at. I know you said your tank leaks. Problem Is i do not know if at my end it leaks because a hole in the tank or it is clogged and over flowing, A lot of times when a machine leaks, is because it backs up like a sewer system when it is clogged, meaning machine might just needs to be cleaned and descaled. So, here is the manual with all kinds of information. Please take the time to read its entirety, especially in the area of cleaning. Thanks Mike.... copy and paste this link into your browser.
http://www.bunn.com/pdfs/commercial/manuals/10424.0000.pdf
Thanks Mike ( The Bean Man)
Oct 01, 2011 | Bunn VPR Coffee Maker
We have a 2 month old bunn coffee maker. worked fine now coffee is taking 10 minutes to brew
Sounds like calcium build up, You need to descale the machine.
If you look at the grounds on the basket, After the brew cycle is over there is like a hole in the center of the grounds. This happens when there is calcium build up in the tank, tube and or spray head. And takes forever for the brew cycle to end.
Follow the instruction on your manual to descale the brewer.
Jan 15, 2011 | Bunn Coffee Makers & Espresso Machines
I have a Bunn CWTF15. Water does not fill the coffee pot full anymore. Is there a float that needs to be adjusted? Would descaling help this problem? Thank you.
If u haven't cleaned it out using 3/4 vinegar to 1/4 water, some times this will happen. after running this thru ur coffee maker, (u won't believe the junk that comes out), then run full pots of water to rinse out (2x's). This should help it perform better.
Sep 12, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
I have mold or lime deposits where the water goes in on my bunn coffee pot what can i clean it.
For lime deposits, you can use a citric acid based descaler/cleaner solution.
For mould or mildew, wash thoroughly in a mild steralising bleach solution (similar to the type you clean a baby bottle with).
When you've used both, ensure you rinse the machine thoroughly several times before using it.
Mar 25, 2010 | Bunn 10 Cup Home Coffee Brewer
Not enough water to fill canister
You might have to descale the boiler on your bunn coffee brewer, If you have the patience I can walk you through it.
Mar 22, 2009 | Bunn CWTF15-TC
Bunn CWT 15-3 (3 Lower Warmers) Coffee Maker Logo
454 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
