Question about Maytag MGR5875QD CleanDesign Gas Kitchen Range
REmove bottom of oven
How do you take the bottom out of a convection oven.
I have model MG5870AQ
  • 45 Answers
That is not the right model number should have 11 char usually mrg5870aaq ,
take all the racks out slide two tabs in the back forward grip on the side lift out. on some units you may need to take the back fan cover off
Posted on May 16, 2008
Bottom oven drawer stuck partially open. Cannot close or fully open. Model #316471000
Hello Dan, thank you for your post!
I understand that the bottom drawer of your Electrolux range will not close and it partially open. It is possible that your rail or drawer may be damaged or blocked. I would recommend pulling the drawer out to inspect it. If you pull the drawer out there should be tabs on the side to unlock in order to remove the drawer fully. The model number you have provided is invalid you can locate the model number on the serial tag. The serial tag can be found on the frame of the drawer. I look forward to assisting you. -Matt
Dec 25, 2015 | Electrolux 30" Self-Cleaning Freestanding...
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
When i turn the oven on, it doesn't give off heat just light.
You will need to post your model number that is located inside the oven or inside the bottom drawer.
Dec 20, 2011 | Frigidaire Gallery 30" Self-Cleaning...
How do you clean a convection oven with aluminum foil burnt at the bottom?
Hello,This is why we say no foil on the bottom...I would put it in self clean and see if it burns it off most of the time it will. You can take the two screws out of the back corners of the oven bottom and remove the bottom and soak it too. Hope this helps...Please rate me Thank You
Jun 09, 2011 | Frigidaire Gallery 30" Self-Cleaning...
Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Jan 22, 2010 | KitchenAid KESC307 Electric Kitchen Range
Oven with convection - when baking cookies, cakes, etc they aren't getting done. Bottom and middle is soggy. Both coils look to be heating, convection fan is working.
Set the temperature one position higher. Convection ovens have a more even heat spread so if you used to bake at the top of your old oven it will now be slightly lower temperature
Dec 06, 2009 | GE Profile JB900BK / JB900KK / JB900TK...
I have a built-in GE electric convection-regular oven. Model JT915W0F8WW. I don't understand when I push the convection baking do I change the baking time? Isn't it suppose to bake faster than the...
As a genaral rule of thumb.. Most recipes can be adjusted for convection oven use by decreasing the temperature by 25 degrees F and decreasing cooking time about 25%. Dishes with cooking times over 45 minutes, and that might dry out too much (like lasagna, or meatloaf) you should cover for the first half of the cooking time, and then remove the cover.
Aug 31, 2008 | GE Kitchen Ranges
Convection oven fan continues to run even with door open and there is an electrical odor.
My JBP90 GE Profile convection oven had the same problem. The problem, in my case was caused by the door switch that controls the interior oven light. It also controls the convection fan and possibly the convection heating element.
1. DISCONNECT THE UNIT FROM ITS ELECTRICAL POWER SOURCE!
CONFIRM POWER IS DISCONNECTED BY OBSERVING DISPLAY GOING DARK
In your case this may mean turning off the 220V double circuit breaker or unplugging the unit cord from its power outlet.
2. Open the oven door
3. Remove the two screws under the front edge of the stove cooktop on the far left and right
4. Gently raise the cooktop 4 or 5 inches and prop it open with a small cardboard box
5. Find the door switch wire and gently pull the switch connector off
6. Remove the switch by squeezing the two metal spring tabs toward the switch and pushing the switch out toward the front
7. Inspect the switch. If its like mine, it may look a little melted and smell burnt.
8. Find a new switch online or at your nearest parts distributer
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=212235
9. Installation is the reverse of above steps.
Good Luck!
Jun 18, 2008 | GE Kitchen Ranges
Oven shutdown
not sure about this one but it sounds like there may be a door switch on your model which is either a probe that the door hits off or it is a micro switch in the side of the oven that the hinge is supposed to strike off.look for these switches to see if connection is being made.
May 21, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag MGR5875QD CleanDesign Gas Kitchen Range Logo
173 people viewed this question
Top Maytag Kitchen Ranges Experts
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
