Question about Maytag Legacy Series Top Load Washer
Water leaking underneath. the back of the washer and all the hoses are dry
  • Maytag Master
  • 17,130 Answers
Check behind , nothing like looking at the fault than to speculate. Can be due tto many reasons but unless the source of leak is understood we may have to give many suggestions. so move your washer , put it to test and watch.
Posted on Sep 14, 2010
This is an Estate Whirlpool washer. It is leaking water from underneath? Check all hoses on back and they are dry(not leaking). Any suggestions?
could be 2 thigs the outer platic tub is broken or transmission or transmission seals are gone, go on line and see how to fix is very easy work on these machines.
Dec 27, 2015 | Estate Washing Machines
My Samsung WA5471ABW top- load washer is leaking from underneath. Is there Nything that I can do to self-repair?
You bet there is. But first let's double check some common causes of leaks that may not be located under the machine. Step one is to check the drain hose behind the machine. If a machine gets pushed back too far it can kink or bind that hose and that can cause water to leak from underneath. If that looks okay check that the end of that hose is not inserted into the drain more than about 4 - 5." If it is poked down into the standpipe more than that it can cause a syphoning situation that can also cause leaking underneath. While you are back there check the hoses that lead up to the machine. Make sure the connections are dry. I can't tell you how many under machine leaks i have fixed that originated right there. Just run a finger under each hose connection. If finger gets wet the connection may need tightened ever so slightly with pliers. If all those check out fine let me know. We'll go deeper.
Jan 13, 2013 | Samsung WA5471ABW 27" Top-Load Washer with...
The washer does not wash the clothes or spin them dry, come out smelling like they were not washed, water leaks from underneath, tries to start on its own and at times will not start at all when you w
Try to clean your coin filter trap underneath and then sanitize the unit before your next wash with bleach water and clean it.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Aug 09, 2012 | Frigidaire Affinity ATF7000E Front Load...
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
About 1 minute into the cycle water starts running out from underneath of the washer. Checked all the hoses that are connected to the back and none are leaking
this is either the front seal that goes from the outer tub to the front of the washer or a hole in the outer tub itself or one of the hoses underneath the seal and the hoses are easiest to check you can take a cup of water and slowly pour it into the front seal. take care not to overfill it to where it spills into the tub and see if you are getting water on your floor from that. the hoses tip the washer up onto its back and look at them from the bottom for any cracking etc. the tub itself can only rust out on some of the neptune models or on others is plastic and can get punctured. just have to look for damage with a light and a mirror.
May 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Leaking water from underneath towards the right side.
The pad is an insulation pad to keep heat in the washer. It might be worth pulling the washer out and checking the water feed and drain connections - it's a good bet one of these is leaking.
Mar 14, 2009 | KitchenAid KAWS700L Top Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Leaks water onto floor while in use
It sounds like a water hose is leaking or has a split in it. Check the water in-take hoses on the back of the washing macine, to see if its leaking or split. If they are leaking, unscrew the hose and check or replace the rubber washer, thats in the brass screw-in part. Next, unplug the washer power cord, unscrew the intake water hoses that are in the back and turn the washer on it's side and check the water hoses underneath the washer. They may be loose or split. Any hardware store should have these hoses in stock, like Lowes or Home Dept, or your local "Do it center".
Jan 19, 2009 | Washing Machines
Kenmore 22992 top load washer
Remove the front panel and youll see.
May 20, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
