Question about HP Photosmart 2610 All-In-One InkJet Printer
LCD SAYS OPEN COVER AND CLEAR CARRIAGE JAM....DID THAT BUT THERE IS NO CARRIAGE JAM
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
  • 1,218 Answers
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t6088190-hp_7400_displays
Posted on Sep 23, 2010
How to clear the reoccuring HP 2610 paper jam error message: The trick is to initiate a print head alignment sequence.
* Open the printer door and press cancel on printer to get the print cartridges to move to the right side.
* Open and close the lids on the ink cartridges (don't need to actually remove catridges), or otherwise get an error message about the print cartridges being wrong.
*DO NOT press OK to click off the message. Close the printer cover.
* In Windows go to HP 2610 printer properties. Click printing Preferences... Services tab... Service This Device... Align Print Cartridges... Align. Click off any additional Windows error messages.
* On the printer, press the Cancel button to start the cartridge alignment sequence. If alignment fails, press Cancel on printer.
This works for me. I hope it works for you.
Posted on Nov 30, 2010
4 Suggested Answers
SOURCE: My printer made a weird noise and now says
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Posted on Jul 08, 2009
  • 273 Answers
SOURCE: My hp photosmart printer is saying Error carriage
Without any paper in the machine I would try powering off and powering on. Lifting the scanner lid will clear so the carrige goes back to the correct side of the printer. Even rebooting the printer and loading the software will sometimes cause the carriage to go back to where it was supposed to be.
Posted on Jan 16, 2010
TPWS
  • 52 Answers
SOURCE: clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Posted on Apr 15, 2010
Testimonial: "Very helpful. My first reaction was to panic that no one oould repair an older printer but this advice got me to calm down and fix the problem."
Carriage jam
Hi
The carriage door is the cartridges access door.Access the cartridges and make sure they're properly installed.To open:
  • Turn the machine on.
  • Open the cartridges door by lifting from the front center of the device until the door locks into place on its own.
Feb 27, 2012 | HP C6250 InkJet Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Clear carriage jam
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Feb 01, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My hp photosmart printer is saying Error carriage jam, open dorr clear carriage jam and then press Ok to continue. Which door should I open and how do I clear the carriage jam? Linda
Jan 16, 2010 | HP PhotoSmart C4180 All-in-One Color...
We had a paper jam in our HP Photosmart C5280 Al-in-One printer. Error message in window reads: Carriage jam! Open door, clear carriage jam, and then pres OK to continue We opened door and even...
after closing the cover and removing the jammed papaer does it still says "paper or carriage jam"????
if it still prompts you that theres a jam and you've already removed it, try to turn off the printer, disconnect from its connections (pc and ivr or ups or wherever its connected) wait for like 5-10 sec then connect it again...
hope this resolves ur prob...
ive experience it to with my hp j3500 all in one... a paper jam, this is what i did and i think it worked for me... hope it do to your printer.. ciao!
Sep 10, 2009 | HP Photosmart C5280 Printer
My display window says open door. clear carriage jam, and press enter. what is a carriage jam?
A cartridge jam, could be that one of your ink cartridge is not in all the way and causing the carriage to get stuck trying to find "HP". You may try to remove the ink cartridges and close the door / cover and let the printer find home and reinstall the cartridges agian... Good Luck
Aug 17, 2009 | Office Equipment & Supplies
HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
Officejet T45
My problem is that it is saying open cover: Clear pen carriage jam, then press enter... what is that?
and the carriage is stuck at corner
Jan 15, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
738 people viewed this question
Seeker5211
Seeker5211
