Question about Comfort Zone Heating & Cooling
I have not used my CZ1000-Wood heater since last spring. I plugged it in today and there is no power to the unit. Yes, I have checked and there is power at the outlet.
  • 5 more comments
  • wbanks2 Sep 14, 2010
    There is no fuse indicated in the schematic for this unit or a "door switch" for the thermostat fan. Can you be more specific as to where this door switch is located and how to access it.
    There is no fuse or "door switch" indicated on the schematic for this unit. Can you be more specific as to where these are and how to access them.
  • 2,299 Answers
I would like to help you with this problem. If I give you my email address you can email me and just put heater in the title. And I will email you my phone number. Then you can call me and I will help you on the phone. It will be a lot easier, faster, and won't cost you anything.
Posted on Sep 14, 2010
  • Rodney Clark
    Rodney Clark Sep 14, 2010
    I didn't put my email address in. Sorry. It is vetteman3002@gmail.com And my name is Rodney. I don't want to post my number on here!
    Brigadier General:
  • 3,917 Answers
Blown fuses
a popped breaker is a short in circuit, first check cord for damage, second it could be heater shorted to block. best checked with multymeter on ohms scale, circuit through block heater is usually 25 to 45 ohms.
Mar 13, 2014 | Duraflame DFS-550-0 Black Metal Electric...
Comfort zone infrared heater
Check the outlet with something else that works. Look around the machine for a reset button. Some machines have a tip-over safety, see if it needs to be reset.
Nov 28, 2013 | Heating & Cooling
Hi I have error code 30 H1 on my Brivis heater, The problem is the fan sometime speed up itself
my power went out last night and today the heat was not working just the cooler , l turned off the main to the heater and the main power and reset the unit but is still the same
Mar 23, 2012 | Heating & Cooling
Heater keeps popping the surge protecter
kheindel,
Try the unit in a non-GFCI receptacle.
If the unit runs fine you have a problem with the neutral having power on it.
Are you using the unit with a two prong plug? Is the grounding stab missing? If the answer to the last two questions is yes then you need to install the proper 3 prong plug.
If this is not an issue then you probably have a bad motor which has contact between the rotor and ground. Replace the motor.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains where to get the repair parts and how to do the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 25, 2011 | Master Heaters B70ET Master
The Cozy Console Pilot flame has been off less than a hour today 07-07 2010 can we wait till the spring time to put back on or call the Gas- company?
Hi, if you are saying that its off now and is it OK to leave it off until spring, yes it is. If you want it to stay off, you can also shut the gas off at the flex line that supplies gas to the unit. Just turn the small handle to the off position, this is just for added safety.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jul 07, 2010 | Cozy Enclosed Front Console Heater 70,000...
We ordered a GWN6 last spring. My contractor
Some units can Be converted,You need to call the manufacturer.I have converted many furnaces but not this brand.
Oct 28, 2009 | Desa International GWN6 Compact Heater
New heater won't fire
http://www.haywardnet.com/locator/ Try setting up a warranty call. If the unit does nothing and you are sure the unit is getting power it will be something either at the cord connection or the control board and under warranty.
Jun 13, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Heater model 5500
You are sure you have power at the plug? If so it sounds like the internal circuit breaker tripped or the switch is bad. Either way, throw the heater away, they are not designed to be field repaired, sorry.
Nov 27, 2007 | R.A.M. Computers LASCO-5540 Ceramic...
Heating & Cooling Logo
116 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
