Question about HP Compaq Presario C304NR Notebook
Laptop i just brought apower cord for my laptop and it will come on and then it will cut back off
    President:
  • 2,712 Answers
Try removing the battery pack and then power up with the cord. If it works, then it means that the battery pack needs replacing/recharging.
If it still dos not work, the cable could be faulty. Get it replaced.
Posted on May 15, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
Where can I get a power cord
Alternatively referred to as a power cable, mains cable or flex, apower cord is the primary cable that provides power to the computer, printer, monitor, and components within a computer. In the image to the right, is an example of the power cord that is commonly used with computers, monitors, printers, and otherperipherals.
Mar 25, 2016 | Office Equipment & Supplies
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
I need apower cord for a singer 3116 simple
try sewingpartsonline.com
or premiersewing.com
Mar 17, 2012 | Singer 3116 Simple
THERE WAS APOWER PROBLEM AND MY MICROWAVE COMPLETELY STOPPED WORKING.NO DISPLAY AND NO SIGN OF AN OUTPUT
Check the main fuse inside the oven on the floor of the cabinet near where the power cord enters.
I believe you will find it needs replacement.
May 27, 2011 | LG Microwave Ovens
My computer is dead and it will not charge at all
I am assuming you mean laptop. If that's the case, your charger should act as a power cord. If you just bought a new power cord and it's still not coming on, bad news for your laptop. If it turns on with the power cord but dies as soon as you unplug it, sounds like you may need a new battery. Check with your laptop builder for info on getting a new one.
Aug 10, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
My computer cannot start
look at the back of the computer. there is apower selector next to the power cord.
change that from 240v to 110v.
Nov 18, 2008 | AMD M863G (M863G15CV22ARV000) Motherboard
I need apower cord for flat screen model# p701 name sl70011ms
usually the power cords are very standard... the power cord communly used has the 3 prongs and has a d shape female/male plugs... try the thrift store.. (I found one that i needed like that.. i had to unplugg it from an old monitor because I did not want to get the monitor so I paid like 2 bucks instead of 10... or just go to a computer store... they may have spares they can sell to you for cheap.
Sep 21, 2008 | Computers & Internet
HP Compaq Presario C304NR Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
