Question about Dryers
I have an estate dryer model # egd4300tq the ignitor will light but doesnt stay lit so clothes wont dry
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 21, 2010
It heats up but doesnt stop after the clothes are dry
IT is the timer. If electronic needs to replace the board. If dial type, needs the timer
Sep 15, 2014 | Dryers
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
The dryer is not heating up. Just blowing air. What do I do?
Gas dryers CLICK when the glowbar warms up the flame sensor to the point that the bimetal inside it bends. This insures the flame is lit. The flames stays on just long enough to warm the drum up to 160f. (for cotton) at which time the flame is shut down until the temp inside the drum drops to 105f when another blast of heat is applied by the control thermostat. If you hear the clicking then the ignitor is glowing AND the flame sensor is shutting it down. That means the thermal limit and control t-stat mounted on the blower housing is working. If that is the case then the coils are bad. Replace them.
How to video
Sep 02, 2011 | Estate EGD4300TQ Gas Dryer
My amana gas dryer seems to be taking longer then normal to dry clothes. I've always used the moisture sensor and one day I noticed it had been running for 10 hours (although the clothes were dry and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 21, 2011 | Dryers
Clothes do not fully dry after one cycle. It takes some times three or more
Clean the vent. If that doesnt work its your heating element.
Apr 26, 2010 | Estate EGD4300TQ Gas Dryer
Dryer will not dry heat but low air flow
check the blower fan on motor shaft,then all vent piping then the vent hose to the outside for a restriction or lint plug
Oct 05, 2009 | Estate EGD4300TQ Gas Dryer
Neptune won't dry clothes -
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing..
Eric
Sep 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
