Question about Mtd 22" Yard Machine Push Mower
Mower won't keep idle, up and down - Mtd 22" Yard Machine Push Mower
  • Mtd Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Sep 14, 2010
Briggs
check the linkage on the top of the carburetor that controls the butterfly, it may be stuck. lubricate the shaft that runs through the carburetor with the butterfly attached to it. This is the Governor linkage
Jul 11, 2013 | Garden
Lawnboy help
ck. governor linkage connections
Jun 18, 2013 | Garden
2006 huskee supreme slt 4600 fuse keeps blowing, any ideas, it's the one by the gas tank
you have a wire grounding causing the fuse to blow you will have to trace wires to see if one is pinched or rubbed raw
Jun 17, 2013 | Garden
John Deer tractor (JD301-A) won't start (no power at all) but if I unplug the carburator solenoid it cranks but it won't start. I need to move it to a roofed are, it is in the field. Is ther
yes a bad solenoid will shut it down if you put power direct to the solenoid and it still doesn't operate its bad with a grinder grind the tip off while your waiting for the new one just make sure you bring down to idle for a few min before shutting it off it a anti back fire solenoid
Sep 23, 2012 | Garden
Starts but won't run faster than idle, then shuts off
Sounds like the float is stuck. Take carb off and clean it. If the mower has been sitting for some time without running, I'd bet that's the problem. The ethanol in gas these days will not keep very long. It's best to drain it all out or use a product like sta-bil.
May 22, 2012 | Garden
2 stroke Victor Mayfair Delux (old mower) Have cleaned our carbi. Plenty of petrol coming from. Can get it started but to keep it running with reasonable revs I have to keep the flooding device down with...
Hi, from your question it sounds like you have an idling problem. To fix this you have to adjust the idle speed screw that is located on top of the carb. Turn that screw in (clockwise) for faster idle speed. Hope this helps. All the best and good luck.
Feb 09, 2011 | Garden
3.5 TECUMSEH ENGINE CRAFTSMAN LAWN MOWER. STORED LONG TIME. WOULD NOT START-CLEANED FUEL SYSTEM -GOT FRESH GAS. LAWN MOWER STARTED-HAS A HIGH IDLE NOW AND WILL NOW IDLE AT NORMAL IDEL SPEED. HOW TO...
Float stuck in open position. When the gas evaporated in it there was a gunk left behind and then It was down and either froze up or there is trash keeping the needle valve from sealing up all the way.
So when you start it gas keeps pouring into the motor. It is suposed to shut off once it gets enough to run on.
Be real careful take the carb off and remove the bowl. And then the float. Take a q-tip and clean the needle valve port ou real good. And clean the rubber tip gently. Then put back together.
When it is upside down the float should be parallel with the carb. That would be the shut off point. You may have to adjust it.
That should do it. When you hook the gas line back up loosen the bowl and let gas in carb til it starts to run out. Then mow.
Oct 02, 2010 | Craftsman Garden
Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Oct 10, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd 22" Yard Machine Push Mower Logo
178 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
