Question about Admiral Refrigerators
I need to replace the door gasket on my old Admiral refrigerator, model # C1042L. Can you help me? Thank you very much. Sincerely, Charles Seidel
  • Admiral Master
  • 17,130 Answers
These gaskets are press fitted on to the slot as the sealing gasket.
So procure the orginal part fromt he dealer for the size,remove by using a blunt screw driver, clean off the grooves all along the door, then place the head tip of the gasket and push into the slot.
The end should be made to merge correctly before it is cut.
Posted on Sep 14, 2010
  • charlesseide Sep 23, 2010
    Thank you for your reply.
    The first problem I have is obtaining the part, which is obsolete, according to Whirlpool, which owns the Admiral brand. They told me the part number is 24157-8 (model number C1042L). If you have any idea where I could get that part, I’d appreciate your letting me know.
    Thank you again.
  • Donald DCruz
    Donald DCruz Sep 24, 2010
    The only possible way since Whirlpool does not have this part is to get the look alike type which is available in many industrial spares stores used for sealign gasketts in multipurpose. so take thsi sample along and it might help. Also some similar types might suit with a fridge spares shop.
My admiral model hmg-64184 is leaking water from the bottom of freezer
It sounds like you have a broken place in the door gasket that is allowing warm air to enter the freezer.
May 29, 2015 | Admiral 26 cu. ft. Side-By-Side...
Samsung SLR550DW - replace the freezer door gasket
Hello Kev;
My name is Peter. I am a retired field service refrigeration technician.
The number that you have provided is your general manual number, which is common to several different models.
Your model number is on the upper inside wall, on a label in your fresh food section.
I have replace many a gasket. Post your model number and I will be glad to help you.
Dec 23, 2014 | Samsung Refrigerators
Replacing rubber gasket
The issues is easy to solve, all you need to do is look at the model and serial of the refrigeration unit and we can match up a gasket for you at www.coolergaskets.com. Once you get it they either push in or screw in, typically screw in. So you would unscrew the old gasket and install the new one. Probably looking at about 1 hour to fix it. We have tech support available that can assist also
Nov 19, 2013 | Admiral 26 cu. ft. Side-By-Side...
Replace doors rubbers
You can order new door gaskets at marcone.com with your model number
Jul 12, 2012 | Admiral 26 cu. ft. Side-By-Side...
We have a 26-ft Admiral side-by-side approximately 15 years old. It still works fine, except the door gaskets are getting hotter and hotter. This trips the breaker in the electric box. Is there a way to...
Hi Sandy and welcome to FixYa, I am Kelly
Usually refrigerators use the condenser plumbing to create heat around the door gaskets. If your getting heat on the door gaskets that means that the condenser fan in the back is either not running or.... the condenser coils are clogged with lint. The fan should be running anytime the compressor is running. Since you said it is starting to trip the breaker.. I am assuming there may be a problem with the condenser fan being stuck or the windings have failed. Without a model number I can not pass you replacement fan parts information. I will say that the average person can change the condenser fan if they just take their time and pay attention to how it is mounted.
Remove the rear lower fiberboard cover:
Check the condenser fan... clean the condenser coils in the bottom rear of the unit. You can..... use and external fan directed into the back of the refrigerator while your awaiting parts to keep the unit going. All your doing is getting rid of the heat that the condenser fan would have done if it was working properly.
If directing a fan at the back of unit does not cause ther temperature around the door gaskets to drop your original assumption of having heating elements between the doors may be correct. Usually units that have actual heaters have an enrgery saver switch in the fresh food compartment that will turn off the heaters.
Thanks for choosing FixYa,
Kelly
Apr 28, 2011 | Admiral Refrigerators
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
Admiral side by side refrigerator won't stay cold.
change the defrost thermostart or check door(ajar) or damper control
Mar 26, 2009 | Admiral 26 cu. ft. Side-By-Side...
The replacement compressor for a TECUMSEH COMPRESSOR S/NO : TP103JR007B5
Actual service call 1080 hd Video on how to replace compressor on refrigerator.
Jun 26, 2008 | Maytag MFI2568AE Side by Side French Door...
Refrigerators Logo
126 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
