Question about Samsung Computers & Internet
Samsung r60 plus does not recognise a/c power,i put in the battery which does not charge and it works
  • 2,567 Answers
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 18, 2010
  • Reg Jan 04, 2011
    This is NOT a poer issue, there is full power to the notebook hence me being able to get the error screens. This is a hard drive/boot issue.
  • anthonywande Jan 15, 2011
    i have the same problem, did you find a answer
Forgot password for samsung r60 laptop
Activate bios on start up and turn off password in the bios is what i do when fixing laptops
Feb 28, 2013 | Samsung Computers & Internet
R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on good. Just because the power cord is new does not mean it works. Some Power Cords have a little green light on the adapter to show that it is plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the fans start up, the hard drive spins? If not, maybe your power cord has enough power to emit a light but not enough to start the fan or disk drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that the battery is not charging, correct? If that is true the things below applies:
Either the battery is bad or the power cord is bad. Just because they are new don't mean they work. See if the Adapter portion of the power cord has a green indicator light that comes on when you plug it to an outlet. If it does, and that light is not on the power cord has issues. Also I hope you did not buy one of those one size fits all power cords from the big box stores where the end has a bag of different interchangable parts until you find one that fits into the laptop. If so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
May 16, 2012 | Computers & Internet
Hallo! Samsung R60 plus, Nachdem ich mir Windows 7 installiert habe, funktioniert die Fn-Tasten nicht, bzw. kann die Helligkeit über diese Tasten nicht regulieren! Haben Sie eine...
Ihr Samsung R60 plus hat Problem beim Anbringen von Fenstern 7 angetroffen. Es ist der Grund, warum die Funktionstasten und andere Anzeigeformate beeinflu?t werden. Versuchen Sie, Ihr Festplattenlaufwerk wieder zu umformatieren und Fenster 7 wieder zu installieren
Nov 04, 2010 | Computers & Internet
My samsung r60 plus laptop, wont boost up, when i turn on the screen is saying,program system not found
This seems to be an issue with the battery of your Laptop.
This is a Reset process & does not mean that the Battery is gone wrong. Try to reinstall teh Battery of the laptop.
But if Reinstalling the battery does not work then battery must be defective.
Hope this will help you to resolve your issue...
Cheers!!!!!
Vivek
Dec 17, 2009 | Computers & Internet
When itry to install my laptop samsung r60 plus
I checked the manufacturer's web-site:
http://www.samsung.com/ca/support/download/supportDownMain.do
and did not find an 'R60' model of laptop.
Access that web-site, and enter the correct model-number,
and download the device-driver for your hardware.
Or, if it is a brand-new laptop, take it back to the retail store,
and ask them for assistance -- they took your money, and they should support you.
Nov 24, 2009 | Sony Computers & Internet
MY SAMSUNG R60 LAP TOP WONT WORK.. THE USER GUIDE IS INSTALLED IN THE COMPUTER SO I CANT ACCESS THAT! IT IS DISPLAYING A RED LIGHT WHICH I THINK MEANS THE BATTERY IS FULLY CHARGED??? BUT NOTHING HAPPENS...
my samsung laptop is green when charged, red when charging.
try turning it on with the power adaptor plugged in and the battery removed.
if this works, i assume your battery is damaged
Oct 01, 2008 | Computers & Internet
Samsung r60 plus notebook keyboard removal
Just need to remove the two screws on the rear marked KBD then turn the computer over and unclip the 7 tabs around the keyboard - 3 at the front and 2 either side, then carefully pull the keyboard up and towards you to release it at the back.
-Deo
Jun 11, 2008 | Computers & Internet
Computers & Internet Logo
748 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
