Question about Power Acoustik FUBAR-12W Car Subwoofer
My vice coil is shot can it be fixed/ - Power Acoustik FUBAR-12W Car Subwoofer
    Genius:
  • 1,144 Answers
Yes a good speaker shop can do a new coil. but it wont be cheep might want to think about a new one. i dont think they make recones for your model.
Posted on Mar 03, 2016
The quick change knob just spins. I can't remove knob. I can't remove blade
Hi Eric:
What is this machine?
It's in the Air and Gas Compressor section, and refers to a blade.
- When knobs "just turn there are several possibles.
1) Knob no longer attached to shaft
2) Anchor nut turning with shaft
3) Threads stripped at anchor nut.
"Shot in the dark" answer that sometimes will herl with (2).............
IMPACT will often loosen something that's giving you grief.
If possible, wrap a rag around the knob to protect it, then attach vice grips, and SHARPLY tap the end of the vice grip handle with a hammer.
Oct 27, 2015 | Air Tools & Compressors
Car does not start. No spark coming from ignition coil
If the starter works and there is no spark at the ignition coil, replace it. Check your center electrode wire too. A new distributor cap and rotor may be in order as well. If that doesn't fix it, your distributor is shot.
Feb 16, 2015 | 1991 Nissan Maxima
No electric current on spark plug
have the codes read, determine if the coils are shot, the crank sensor is shot, and the less likely and most costly repair would be the ECM is shot. after you have the codes read (for free at local parts shop) you can fix the problem
Oct 10, 2013 | 1996 Toyota Tacoma
My honda 5hp engine electronic ignition rewind rope broke and I am having trouble installing the new rope and getting it to work
might seem like a easy fix but they are very awkward to try and fit you need to take the case of were the rope goes into but when un doing the case and removing you must do it very slowly as the coil spring is under exstreme pressure and if the coil spring pops out of the casing then it is a nightmare trying to put back together but if you manage to get it of in one shot you will see how the rope is tied and were it sits in the groove so you need to remove the old knot from the rope and refit your new one and try and keep the tension on the coil spring a little hard to exsplain but give it your best shot and wear some glasses as the coil spring can go all over the place as it is wound up several times to create the tension for the pulling action and to retract back if it dont work out for you just keep all the parts and take it to your local tool repairer and they should fix it for around 15 to 20 dollars
Jul 06, 2011 | Garden
How do you make adjustments, towards the shot or towards center of the target?
You move the cross hairs to the shot. Set up your gun on a bench and start by firing at a target out at about 15 yards. Once you are "on paper" set your cross hairs on the center and fire a 3 shot group Adjust the scope to the group. if the group is down 3 inch and left 4 inch. Adjust your scope accordingly. Then Fire another 3 shot group, until you are shooting center. Every time you adjust your scope tap the barrel of the scope with a screwdriver handle to keep the cross hairs from sticking. Once on at 15 yards move out to your max range and adjust to that.
Mar 19, 2011 | Brunton 2x20mm NRA Sports Optics Rifle...
When I raise the cross hairs on the scope on the graft the bullet goes down and when i lower the cross hairs the bullet goes up is this correct. When I bought my pursuit boar sight from Basspro I only...
That is right. If you had the rifle held in a vice aimed at a particular point and without moving the rifle you raised the cross hairs you would now be aiming above the point. To get your aim back onto the same spot you would have to loosen the vice and lower the barrel of the rifle. This would mean that the next shot would hit the target lower down. The same is true if you lower the crosshairs which means the bullet would rise.
Likewise moving the crosshairs to the left brings your shot to the right and moving them right brings your shot to the left.
Sep 15, 2010 | Sport & Outdoor - Others
The aircon is not functioning; the clutch is not
If the freon is too low it wont kick on the compressor. I hope this helps!
Jul 23, 2010 | 2003 Ford Expedition
No spark at plug. so iam guessing coil is shot. mac 110
Hi
You will have to remove the engine from the houseing to get to the coil.Not a easy job. It does not have points
Sam
Jan 07, 2010 | Poulan Pro Chain Saw 46cc 20"
My elevation and windage adjustments aren't moving my scope. I shot 4 times and my group is 1 inch. Problem is I adjusted my scope between all 4 shots. I'm consistently shooting 7 inches high and 3 inches...
This can only be due to a "broken" scope. To be sure, you can put your gun in a vice (cushion it) and put the crosshairs on a fixed point. Without moving the gun, crank the adjustment knobs a good 10-15 clicks in one direction each, and see if the crosshairs move from where you had them pointed.
If they do not, the scope must be replaced. If they do move, perhaps you should try adjusting the scope quite a bit more between shots.
The best way to sight it in requires a helper. Fire one shot with the crosshairs on the bullseye. Then, without reloading, put the crosshairs back on the bullseye, and have a friend adjust the knobs until the crosshairs move to the ACTUAL point of impact of that shot. It is essential NOT to move the gun while doing this.
This method allows me to sight any gun in with only 2 shots (and a few for confirmation, of course). Best of luck!
Nov 23, 2009 | BSA 3-9x40 Deer Hunter Riflescope
Max 890s coil nailer does not advance nails when operated.
Make sure you have at least 100 psi available and I would pretty much drown the sliders and other moving parts in something like Marvel Mystery Oil.
Feb 26, 2009 | Mx Max Cn890s Coil Nailer O`ring Parts Kit
Power Acoustik FUBAR-12W Car Subwoofer Logo
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
