Replace the roller in the paper draw first, try a different paper draw if that fails replace the paper draw roller as, then have the rollers though out the machine cleaned, get tech to come out and look the machine over very old machine might need maintenance
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: paper jams minolta 1080 cspro copier
Can you explain where exactly the paper jams, just check any obstruction in the paper path, or clean all the clutches/ sensors for registration and transport
SOURCE: MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
SOURCE: minolta di181 says paper jam no. 6. Where is no.
On your operation panel is a graphic of the copier with numbers on it. The 6 area is on the right side of the copier. Look at the door labeled R1. This is the area as well as the 2 paper trays. I would check those as well.
SOURCE: minolta cspro 2010 error code c05
pLEASE DESCRIBE YOUR PROBLEM CORRECTLY.tHE 05 CODE REFER TO FUSING UNIT.Check or change the fuser unit components,clean the thermofuse and thermistors.
