Question about Akai PT5492S 54" Rear Projection Television
Cleaning the screen
Can the front of the screen be cleaned and with
what
    Sergeant:
    Champion:
  • 248 Answers
Just use a cloth or you can also use alcohol to clean it.
Posted on Jun 22, 2008
How to clean sreen and lens
In order to clean the Picture Tube Lenses you will have to remove the front screen. As for cleaning the screen use only correct screen cleaning solution or just replace the front screen if it is streak to badly.
Oct 08, 2012 | Mitsubishi WS-55613 55" Rear Projection...
1) how to clean the lens of camera? dust went inside display how to clean it?
Lens can only be cleaned outside on the front surface. Use T-shirt washed with detergent then dried, never rinsed. otherwise you have to change the lense assembly, in front of the sensor. That is a big job.
Display is lcd in front of LED light screen. You can clean between led screen, lcd and also casing screen using cotton T-shirt material, after you disassemble the camera.
Nowadays, digital cameras are disposable, not worth fixing. Buy a new and better one soon.
Mar 19, 2011 | Kodak EasyShare M530 Digital Camera
Spilled fluids on screen
yes. there are actually two screens sandwiched together. a fresnel and lenticular screen(lens) fluid got between them you have to take the screens apart and clean between them. you just cant clean the front and back. you have to take screen apart and clean both fronts and backs. that will fix it
Nov 11, 2009 | Televison & Video
Does the front panal around the screen of my Mitsubishi VS-50707 come off for cleaning behind it?
Yes, front screen can be removed to clean projection mirror and picture tubes lenses.
Remove speaker grille, pull them to remove.
There are 3 screws at bottom of front screen, remove them. There are few wire harness plugs need to be disconnect to remove completely front screen.
Below exploded view of Mitsubishi VS-50607 will help you to remove front screen to clean inside. Be careful while removing screen.
Oct 23, 2009 | Mitsubishi Televison & Video
50 in philips projection tv
Much like anything in your home, TV screens get dirty with fingerprints and dust and require a periodic cleaning. Keeping your TV screen clean is essential for ensuring a clear picture. However, cleaning the front of your TV is not something that should be left for the cleaning lady. The use of certain cleaning products and solvents can damage the front of your TV screen. Special care must be taken in order to make sure that your TV screen is cleaned properly.
Every kind of TV has different steps for proper cleaning. If you are unsure what kind of TV you own, consult your TV user's manual to ensure that you are using the right cleaning method.
  • Direct-View - Older direct view TV's can be cleaned with glass cleaner and a paper towel. Newer tubes that may contain any special coatings, like an anti-glare coating, should be cleaned with a damp cotton cloth. If you are unsure if you have any special coatings, it is best to be safe and use the damp cloth.
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products GA_googleFillSlot("TL-IMU-Article"); b3342371.3;abr=!ie4;abr=!ie5;sz=300x250;ord=[timestamp]? can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • Microdisplay Rear-Projection - All microdisplay TVs have some sort of screen shield on the front. These TVs should be cleaned with a damp cloth. Microdisplays with a shiny screen shield can be cleaned with a mild soap if extremely dirty. Those with a flat screen shield should not be cleaned with any cleaning agents. Do not use paper products to clean the front of the TV because they could scratch the screen surface.
  • Plasma - Plasma owners should clean the front of the TV with a soft, damp cloth. The use of a mild soap for heavy cleaning is acceptable. The use of heavy cleaning agents could strip the special coatings on the screen, and paper products can scratch the front of the TV.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press hard on the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
When dusting the TV cabinets, dust with a damp cloth or a mild cleaner. Paper products can scratch the surface of high-gloss cabinets, so avoid paper products. Heavy cleaners can strip the finish off of TV cabinets over time. When cleaning speaker grilles, dust with a dry cloth. Wet cleaners could stain or damage the grille cloth.
Jan 29, 2009 | RCA P52926 52" Rear Projection Television
Cleaning the screen cover on my sony big screen
To clean its front screen, you should not open front cover as its complicated procedure. just take off its back cover as its shown in picture and use air-blower to clean dust. Then use soft cotton cloth to clean its screen from internal and 3 bulbs / lenses (CRTs) and job is done.
Need further help, let me know.
Bye.
Sep 13, 2008 | Sony KP-57WV600 57" Rear Projection...
Front screen
HOW TO CLEAN TV SCREEN;
  • CRT Rear-Projection - Before you can begin cleaning, you need to determine if you do, or do not have a screen shield. A screen shield is a hard plastic cover over the front of the TV screen. If you can't tell, give the front of the TV a light tap. Another way to tell is to check for ridges in the screen area. If you can feel ridges on the screen, then you do not have a screen shield. Rear projection TVs without a screen shield require a special kind of cleaner and rag. These are available for purchase at your local TV service center. Those that do have a screen shield should be cleaned with a dry or damp soft cloth. If it's extremely dirty, a mild soap may be used. Do not use paper products, such as paper towels, to clean the screen shield. Paper products can easily scratch the surface of the shield. Screen shields can have a tendency to streak while cleaning. If this happens, use a dry cloth and buff the screen in a small circular motions.
  • LCD Flat Panel - Be careful with flat panel LCD TVs! Use a slightly damp soft cloth to clean the LCD screen, then immediately dry with a soft cloth. Do not press ******* the screen during cleaning. Doing so could cause severe damage to the display. Do not use any cleaning solvents, such as glass cleaner or soaps, to clean the LCD screen. Paper products could scratch the front of the screen. If you have a pet or child that rubbed something on the screen that you feel could stain or damage it, contact your local TV service center for assistance.
Hope this may help;
DON'T FORGET TO RATE:
Sep 06, 2008 | Toshiba 55H70 55" Rear Projection...
Cleaning screen on my 1080i hd panasonic????
GA_googleFillSlot("TL-Leader-Article"); Hope this may help; DON'T FORGET TO RATE;
Aug 31, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Screen
Oct 25, 2007 | Hitachi 51G500 51" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
