Question about GE Refrigerators
Freezer cannot reach 0 degrees. refrigerator is okay.
  • GE Master
  • 17,129 Answers
Maybe the gas pressure needs a fill up or the compressor must pump more. Check for the capacitor of the motor. If weak the speed can be low and pumping reduced thereby reducing the cooling.
Posted on Sep 14, 2010
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Kitchenaid KBFL25ETSS00 bottom freezer refrigerator
You mean the temps are getting warmer? Look inside the rear of your freezer and back wall and tell me if you see snow or a layir of frost building. If so pull everything and unplug and do a manual defrost a hair drier will speed things up.Sounds like we need to use the tech sheet here but Kitchenaid will not allow me to publish here. So Skater125 you need to click here and I will send it to you only, Thanks, Sea Breeze
Posted on Sep 17, 2011
1998 GT22DKXGN00 refrigerator freezes, where is thermostat in refrigerator ? This is a Whirlpool
Check refrigerator and freezer temperature. If the freezer is above 0 degrees Fahrenheit it is likely the cooling capacity of the unit has reduced due to low charge or weak compressor. What usually happens is that the freezer is not able to reach the proper temperature and the unit runs continuously. The result is that the refrigerator via the freezer-refrigerator air flow connection freezes.
"This is not intuitive", but the logic is that from the compressor running continuously the freezing air that flows into the refrigerator side results in that the refrigerator will freeze,.
Check the temperatures. If the freezer is above 10 degrees F it is almost certianty the cooling capacity has been reduced.
If equipped with an ice maker the output of the ice-maker will also reduce with this problem
It is possible to have the compressor replaced but not usually cost effective.
Apr 10, 2017 | Refrigerators
I have both freezer and refri setting on 6...is that okay?
It does not matter as long as the temperature inside each is correct. 35 to 40 degrees F in the refrigerator and 0 degrees F in the freezer.
Oct 06, 2015 | Frigidaire Refrigerators
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
We bought this refrigerator last year and have been very happy. However a few days ago the freezer temperature (which should be at 0) has been creeping up to about 8-10 degrees and now the non freezer...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Jenn-Air JFC2089HE French Door...
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food.
Step 2
Place your magnetic thermometer in the refrigerator.
Step 3
Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
Step 4
After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
Step 5
Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Our Kitchenaid KBFA25ERSS01 freezer suddenly does not stay at 0 degrees. Fluctuates between 2 degrees and 12 degrees.
Sounds to me like you could have some serious problems. What you're seeing could be either the result of faulty electronics (i.e. the thermostat) or an even larger problem with the refrigeration system itself.
About the only thing that I could think of that could be repaired by the user would be the door seals if those are leaking. Anything more intensive than that though and your best bet is to contact a service person.
Jul 29, 2009 | KitchenAid Refrigerators
What is the recommended temperature?
Reach-in refrigerator, 38 to 40 degrees Fh
Reach-in freezer 0 degrees Fh
Jun 06, 2009 | Frigidaire Professional Series PHS68EJSB...
Fridge freezer samsung model no sr-s2028cvw
fridge side should only be around 36 to 40 degrees freezer side around 0 to10 below
Apr 13, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
