Question about HP LaserJet 1020 Printer
Paper is stuck - printer was turned off mid-print
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
These steps will help you clear paper jammed in this printer.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00311028&cc=us&lc=en&dlc=en&product=439320
The video shows the same thing.
Posted on Sep 14, 2010
My paper keep getting jam and will not go into print
  1. Turn off the printer.
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persists and you see no paper that is stuck in the printer it
May 14, 2011 | Office Equipment & Supplies
I keep getting paper jams. Even if I put one sheet of paper in at a time, the paper keeps jamming and won't print.
Hi
I live in the mid west - during our significantly humid days my 926 wouldn't pull in any paper. I tried a lot of home grown techniques but none worked. I finally raised the air temp in my office which tended to dry out the paper and that worked. Of course your problem could be a broken gear or a worn out feed tire - also something stuck in the printer.
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
A piece of paper is stuck inside. I tried to pull it out from the paper tray end but it has now receeded and I cant print or get it out, any ideas?This occurred when I stopped the print run mid- print by...
Just open the front door and take out he toner/drum cartridge, remove the paper cassette, best is to pull the paper forward toward the inside of printer, if none is visible you can push an index card up from the front to push out any scraps.
Feb 01, 2010 | Brother HL-5240 Laser Printer
Regular paper jams and printed images are not straight
hi,
follow these steps:-
  2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
  3. Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
  4. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
  5. Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue and i suggest contacting theprinter manufacturerfor additional assistance and/or repair.
Thanks!
mannu_rakesh
Aug 04, 2009 | Brother MFC 240C All-In-One InkJet Printer
BROTHER PRINTER HL-2140
Try turning the printer off and back on. if this doesn't help, open any cover that will open and look for paper still in the printer. many times, if you stop the printer mid-job, paper will be stuck in the back of them, and most printers will not recover until you remove the paper jam.
Feb 10, 2009 | Brother HL-2040 Laser Printer
Printer cartridge stalled
# Turn off the printer.
# Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.*
# Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.*
# Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.*
# Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issue
Feb 06, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Paper jam
NEED TO FAN THE PAPER AND ROLL THE PAPER THAN SURF IT LIKE IT IS ON WAVES OF WATER,
STRAIGHTING OUT PAPER
MAY NEED TO TRY DIFFERENT TYPE OR BRAND OF PAPER.
THERE IS A PROGRAM THAT MAY HELP YOU WITH THIS PROBLEM IT IS CALL
GREENPRINT WORLD DOWNLOAD
ENTER
ROD
Jan 30, 2009 | Canon i850 InkJet Photo Printer
Paper feed
What the hell, I have a mid-term that is due and I need this thing to work, What a piece of ****!
Jan 10, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark printer problem on HP-UX
You should check your drivers to be sure the Lexamrk ones are being used and that the HP ones have been deleted.
Dec 06, 2007 | Lexmark C510 Laser Printer
HP LaserJet 1020 Printer Logo
87 people viewed this question
Ben Johnson
