I have a set of bose speakers that i want to connect to my computer, instead of using my monitor speakers How do I connect them?
  • Renee Sep 14, 2010
    Currently the green port has the monitor speaker in it, do I take this out and add the bose, or use another one I have six colors on the computer
    didnt work
  • 6,487 Answers
If you have that Bose speaker , you just need to connect it to your computer tower on the back part of the tower look for a yellow-green port there usually its located in the middle of other colored port.
Posted on Sep 14, 2010
  • Mark Gil
    Mark Gil Sep 14, 2010
    Yes you need to take out the monitor speaker from there and connect the Bose on it and then restart your computer.
  • Mark Gil
    You can also try the other green colored port there.
I purchsed a new LG Monitor and installed it to my 4 year old Gateway Computer,now have no sound coming from my Bose speakers! HELP?
I answered this but the solution did not post (thanks to Verizon). When you installed the LG software, were you prompted to change any settings? The LG software may have hijacked your normal sound output to your Bose speakers
Nov 18, 2012 | LG E2242T-BN Black 21.5" 5ms Widescreen...
I have a Bose lifestyle 50 (from 1999) and just purchased a new Sony Bravia TV. How can I connect the TV to the Bose sound system?
hello!
unless your "Bose" has an optical or coaxial digital stream audio inputs, there is no way of connecting TVs audio output to your receiver(home theater). to by pass the TV itself, connect analog audio output off your cable or set top boxes. those, still have analog audio out. If you need to connect more audio sources, use TV as a video monitor, connect all the audio outs to your "Bose", instead. In case of terrestrial broadcast, you may need to obtain digital converter box and use it simultaneously with TV to get your audio out. Also, if you lack DVR, that box will allow you to use regular DVD recorder. It's not going to be HD quality, but better, than nothing. You can't feed HD video signal out of TV set.Only analog.
good luck,
Alex.
Feb 01, 2012 | Bose Audio Players & Recorders
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Aug 19, 2009 | Bose 901 VI Main / Stereo Speaker
No surround sound
It sounds like the speaker wires are mixed up or maybe a setting on the reciever is wrong. Verify your speakers are properly connected. you test speakers using a 9 volt battery or smaller.
Jun 19, 2009 | Bose Lifestyle 12 System
Bose 901 series speakers to Bose 901 Equalizer
There is no direct connection between the 901's and their Active Equalizer. It is designed to be inserted between the source and the DEDICATED amplifier driving the speakers. Typically, this would be in a Tape Monitor loop on a receiver.
Tape Rec/Out to EQ In; EQ Out to Tape Play/In on the receiver. If you have a tape deck(s), it(they) would go into the back of the Bose EQ as if it was the receiver and you would use the Tape and 1/2 buttons for selection.
Or,if you have access to any other point that doesn't use the Tape Monitor, like a Pre Out/Main In jumper set, place the Equalizer there. That way it's always in front of the speakers and doesn't take up the Tape Mon.
Flip in the Tape Monitor and leave it on or the speakers will not receive the essential ACTIVE Equalization they require for proper frequency response. DO NOT place non-901's onto any amp using the Active EQ.
Like any speakers, the 901's will attach to the speaker terminals in the conventional manner.
Apr 12, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 3-2-1 - trouble connecting to Samsung 26" LCD monitor
Sounds like you might be out of luck with the older 3-2-1 system. I am in the same boat, and am thinking I will only be able to utilize the "audio out" on the back of my Samsung LCD, and run that to the "aux in" on the Bose 3-2-1. This of course will not allow me to utilize the 3-2-1's DVD player, but by using a seperate DVD player, such as a Blu-Ray hooked to the LDC TV, the video will make it to the screen, and then the audio should make it through the Bose 3-2-1 speakers. Probably not the "best" solution, but one that I am going to attempt.
Mar 25, 2009 | Bose 3 2 1 GSX System
Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Dec 15, 2008 | RCA WSP150 Main / Stereo Speaker
Tivoli Stereo Speaker
Any speaker has the potential to be used as a computer speaker. The problem you will run into is what will be used to power the speaker. Typical computer sound connections do not put out a strong enough signal to power a full sized speaker on their own. If you hooked the computer to an amplifier and then to a speaker it would work fine. If you do this, I recommend using the line out connection on the computer instead of the headphone connection.
Jul 20, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Connecting Bose Companion 3 to HP Pavilion Desktop (Elite m9150f)
you have to configure your sound at control panel; you have to switch from computer speakers to external, with or without a woofer. Easy shreazy.
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
