Question about LG DLE5977 Electric Dryer
Lg model dle59772 will not heat drum runs ok - LG DLE5977 Electric Dryer
  • LG Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Sep 15, 2010
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
Lg dryer fuse keeps blowing but the heating element and thermostat all have continuity
I have been using an LG domestic dryer in a commercial application (motel) for 5 years and the only problem has been a lint build up inside the dryer because of an improper vent installation. The problem is likely in the dryer drum motor, it runs for a short time heats up because of bad motor bearings, improper motor cooling or bad drum bearings (motor drives the drum) increased heat = increased amperage= blown fuse. Motor should go out on overload but it may blow a fuse first. Is the fuse in the electrical panel or in the dryer? Try turning the dryer drum by hand and check for resistance, there shouldn't be much. The motor needs to cool so pull the dryer panels apart and vacuum the inside first and make sure the motor and interior has been thoroughly cleaned. Try this for a quick fix first.
Jan 31, 2015 | LG DLE3777 Electric Dryer
Lg DLE2240w
it is hot inside and the drum turn? yes: look for lind in your outlet pipe. no: the heat element or the thermal fuse is out. if the drum dont turn, change the strap. (is all this are ok, look the fan impeller) tank you
Mar 29, 2014 | LG DLE2240W Dryer
My LG gas dryer model DLG 2555W runs but produces no heat
Gas out. That is the problem. Refill Gas.
Aug 11, 2012 | Cell Phones
Lg dryer dlg8388 , with power on drum runnng but no heating up, i'll check continuity in the igniter and is ok. don't lnow what else to check.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Aug 25, 2011 | LG DLG8388 Dryer
LG dryer. the drum will not turn with wet towels in it. When it turns it does so slow and the contents do not tumble but get bundeled up in knots. The belt seems ok, it did make a "squeeky"...
If indeed the belt is OK, with it's grooved side touching the drum, and the belt running in the motor drive pulley (not on the smooth motor shaft), then you most likely need to replace at least one of the four drum support rollers.
Jul 10, 2011 | LG DLE5977 Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
51 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
