Question about Sony Ericsson K530i Cellular Phone
When i on my phone a massege appears on screen insert correct sim card. what should i do?
    President:
  • 2,360 Answers
It may be due to network lock,
you can unlock it and switch over to another network , you can get unlock codes here http://www.theunlockarena.com/supported-phones/rs13wp7/
you need to specify the country and network provider
Posted on Jan 20, 2011
Insert sim card
Do you want to insert other network sim or if your Blackberry Curve 8350I displaying insert sim card,if already sim card inserted.Don't worry i will help you.You can insert other network sim card in the phone by unlocking the phone from current network lock.To unlock Blackberry Curve 8350I use unlock code.Visit the site Wickedunlock.com get unlock code and unlock it easily.Then insert any GSM network sim card.If the phone displays insert sim card even though sim card is already in the phone.Please remove the sim card and replace it correctly.It is because the phone didn't detect the sim correctly.After inserting if it is display invalid sim or sim not valid message on the screen.It is locked to some network,you need to unlock it.To unlock use unlock code.Get code from online site and unlock it.
Jul 30, 2013 | Blackberry Curve 8350i
Micro sim will bounce off every time I insert the micro sim in my Sony Xpeia P phone
Hi,may be your unlock phone didnt unlock correctly before,i think 98% you have software crack issues,try re unlock it by certified shop,if you still have problem may be your ESD SIM CARD PROTECTOR IC (contain zener diodes inside to protect sim card from electro static charge) is gone,and must change, so go to a certified store to repair it
kind regards,
Apr 17, 2013 | Sony Ericsson Sony Xperia P Lt22i 16gb...
Solving the nokia6120c insert sim problems
There are some possible solutions:-
1. Check that your sim card is in perfect condition by insering the same sim card in any other mobile phone... If the same message appears that means the problem is in your sim card
2. Check that your sim card's slot is in perfect condition by inserting any other sim in your mobile phone... Still if the same message occurs that means the problem is in your sim card's slot
3. Check that you are inserting your sim card correctly or not
Aug 27, 2011 | Nokia 6120 classic Cellular Phone
How i will initialize my SIM card?Should i enter my SIM PIN number?
Hi
Remove the battery from your phone. Slide off the back cover of your phone to get to the battery. Gently lift the battery from its compartment to remove.
Insert the SIM card into your phone. Once your battery is removed, insert the SIM card into your phone. Look at the image on the phone to see how to insert the SIM card correctly. Make sure it is pushed all the way into place.
Replace the battery and turn on the phone. Replace the battery back into its compartment and replace the back cover. Turn on your Nokia 2610 phone, and it should boot up. The name of your wireless provider will appear when your phone is turned on.
Allow time for your phone to read the SIM card. Once your phone is booted up, it will say initializing. This means that it is reading your SIM card information. Once your SIM card is read, your phone will go to the home screen. Your SIM card is now activated, and you should be able to access all of your information.
Please accept the solution if it's helpful. Do get back to us for any further query.
Sep 20, 2010 | HP iPAQ h6315/h6365 Pocket PC
Insert sim
Is your sim card in the phone? Make sure it is inserted in there correctly and if it is and it still gives you that message the phone has a bad Sim card reader and although your sim is in the phone it is not reading it.
www.usedcellphoneshop.com
May 28, 2010 | Motorola Mobility RAZR2 v9 Cell Phone
My sellphone get block and now said insetrt sim but the card is there an dstill said the same thing?
First, make sure you have the SIM inserted in the phone correctly. If you do - and the phone still doesn't recognize the SIM card - you may need to replace the SIM card.
This is a common problem with some phones especially when the SIM has been transferred from one phone to another.
Just about the only way to correct it is to replace the SIM card with a new one.
You can purchase one on eBay for a few dollars instead of paying $25 at a retail outlet. Once you receive it, carefully pop it out of the card it is attached to and correctly insert it into your phone.
Put in your battery and turn your phone ON. You should see a 'No Service' message on the screen. If you do, then your phone can now recognize the new SIM card.
Look on the larger card you removed the SIM from and get the SIM number from the card. Then call your service provider and inform them you have replaced a defective SIM card with a new one in your phone. Give them the new SIM card number and in less than 1-minute your phone will be working again.
When it does, the message on the screen will change from 'No Service' to the name of your cellular provider.
Apr 01, 2010 | Pantech C300 Cellular Phone
Phone says insert sim card with sim card already inserted
Mar 29, 2010 | Samsung Beat SGH-T539 Cellular Phone
I have SIM lock on my Samsung X660 and I do not know the password.
put a non-accepted sim card, turn the phone on, and when you receive the message "insert correct card" or something like this, press:
*#9998*3323#
press "exit" and a menu will appear
choose the 7th option from this menu
wait until the phone reboots (it may take a while), don't worry if you will see some weird things on the screen.
Nov 15, 2008 | Cell Phones
The phone stops switching on.Stopped switching off.can not recognise sim card
the sim card may be in the wrong way , look carefully at that
but if the phone is having problems starting up or working correctly you should take it back for another one , also these phones have been having problems with the screen comming on , so there is some problems with some of these phones
Nov 06, 2008 | LG Shine KE970 Cellular Phone
Insert sim massege
Try to reset the (?make/model?) phone to original settings, if you can access the menu without the SIM card. The reset to factory settings will be there somewhere.
Feb 05, 2008 | Cell Phones
Sony Ericsson K530i Cellular Phone Logo
64 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
