Question about Ricoh Aficio 1035 Copier
My Copier Machine Model is Ricoih Aficio copier Machine, so 542 error comming now Not printed
  • 67 Answers
Change thermistor
Posted on Jul 08, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
The serial no is M0965802358 and the error message is SC542. Help
the SC-542 means your machine thermistor open please change it -thanks
Dec 08, 2010 | Ricoh Aficio 2015 Copier
Sc:542 error message on the screen
You need a firmware update…
SC542 SP1-103-2 Off + Temp has been newly added to prevent SC542 from occurring at machine power-on under low-temperature conditions.
Note: For this fix, it is necessary to use Controller firmware ver5.15.1 or newer.
Apr 02, 2010 | Ricoh Aficio 2015 Copier
"xerox machine ricoh aficio 1018d error code ca:542 "
you have a fuser code. power cycle the machine. use the red off/on switch. turn off for 30 sec. turn back on. if code is still there have a tech fix it. could be bad thermistor, measures tempature. bad lamp, creates heat. thermofuse, protects from met down,. bad power supply, supplies power. bad main pcb, controls everything. most likely needs fuser rebuilt
Dec 31, 2009 | Ricoh Aficio 1018D Copier
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
I have a ricoh aficio 2035 that reads error sc 542
Fuser warm up error. Repair problem (fuse, lamp, thermistor etc.) then reset code in service mode.
Jun 25, 2009 | Ricoh Aficio 450 Copier
Error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Mar 28, 2009 | Ricoh Aficio 450 Copier
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 1035 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
