Question about Maytag MSD2656G Side by Side Refrigerator
Maytag 2 Door Refrigerator (1 yr old)
I plan to live 6 mos. in another place.  Should I unplug my Maytag refrigerator  in my home since I will be gone for that amt. of time or turn it very low?
  • 45 Answers
The rule that i follow is ,not used more than two months unplug open doors and air out.
Posted on May 16, 2008
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    I have a 10 yr old Maytag MTB2156GE, it has been making intermittent loud cracking noises for the last week or so, came home today it has stopped working. Can it be fixed? Is it worth fixing?
    sounds like the condenser fan motor is bad check in the bottem back of the unit if the fan works if not replacing it is worth on a 10 yr old machine
    Sep 02, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
    Maytag refrig (french door) water and ice on door stopped working at the same time.
    1) Electric Water valve check up.
    2) Water/Ice dispenser control check up
    3) frozen plastic pipe inside door or/and chilled water container frozen
    4) old water filter (clogged)
    Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
    Leveling refrigerator
    you might lower the front ones to get it level thats the only sloution i can come up with
    Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
    GE Side by Side Refrigerator
    Door Alarm -
    To set the alarm, press this pad until the indicator light comes on.
    This alarm will sound if either door is open for more than 3 minutes.
    The light goes out and the beeping stops when you close the door.
    Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
    In a Home the recommended level (front higher to back lower) is 1/4" (Right to Left - level)
    Never less than in order to allow door to shut own their own, but there is nothing wrong with having a perfect level refrig if everyone closes the doors properly which they won't. A refrigerator requires to be reasonable leveled to avoid compressor fatigue. In a Motorhome people can't always find level ground, so it quite frequent that their refrigerator burns up when running. From that experience I'd say I would level any fridge which is over 1/2 inch off.
    Nov 02, 2007 | Maytag (MFI2568AEW) Bottom Freezer French...
    Maytag MSD2656G Side by Side Refrigerator Logo
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
