Question about Frigidaire Microwave Ovens
FRIGIDAIRE Over the Range Microwave Model # CPLMV168CC1 Serial # LA41707633 Its not heating up. Please help. Thanks, rizacfb@rogers.com
MicrowaveSvc
  • 9085 Answers
SOURCE: Kenmore over the range Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Dec 05, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Problem with Frigidaire CPLMV168CC1 Over the range microwave
I would suggest a hard reset - unplugging it for a few minutes then trying again.
If you don't have the owner's manual, you can download it here:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316137207en.pdf
If it doesn't have an option to turn sounds on and off, you may have a problem with the keypad or control board.
Moisture may have gotten into the controls from steam (from not using the exhaust fan while cooking on the stove top) or spray cleaner (from spraying the keypad directly instead of spraying it on a soft cloth).
Please reply back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 07, 2008
drumbanger
  • 1199 Answers
SOURCE: Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Posted on Jan 13, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: Frigidaire Microwave OTR FMV145KS2 not heating
Chances are it's a defective high voltage rectifier diode or magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download Frigidaire owner's manuals and installation instructions can be downloaded through the links here. where you can also locate a nearby authorized servicer if you choose.
The magnetron has a 10-year part warranty, but you would have to pay labor.
If nothing else, you can save about $75 by taking it to the shop yourself.
Good luck.
Posted on Jun 17, 2009
erpaalai
  • 999 Answers
SOURCE: Our frigidaire microwave won't turn on
The reset is because it lost power at some point. There could be a loose wire internally or a blown fuse. Your call to open the console and check a few things your self or call fr service. Eric
Posted on Sep 15, 2009
How do I tighten the door handle on a Frigidaire over the range microwave oven?
You need to remove the inside part of door to gain access to mounting screws.
Nov 19, 2015 | Frigidaire Microwave Ovens
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
I have a model plmv168kc2 serial pg13903700 frigidaire microwave\r\nthat made zzzzz noise then quite heating , every thing else seems to work but willnot heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ';
Apr 19, 2011 | Frigidaire Microwave Ovens
Model FMT148G1B2 - over range microwave will not heat food. Clock, lights, rotating plate in M/W all work, just will not heat/warm.
well that depends on the current. If the current is a fluctuating type then microwave wouldn't heat or else if high...please check..
Jul 23, 2010 | Frigidaire FMV156EM Microwave Oven
Sep 03, 2009 | Microwave Ovens
Looking for Installation Instructions for microwave.
Yes to all of your questions. There is a mounting bracket which is specific to this model.
here are the installation instructions http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-InstallationInstructions.pdf
here is the owner manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-Manual.pdf
here is the witing diagram
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-WiringDiagram.pdf
and here is the parts manual
http://www.ajmadison.com/ajmadison/itemdocs/PLMVZ169GC-PartsManual.pdf
Download these manuals and you will have all of the info available on this microwave. Check to see what is missing and then get what you need by clicking on this page and the where to buy line
http://www.frigidaire.com/customersupport.aspx
enjoy your new microwave.
May 23, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Appears normal
ya this is the same problem i too had...everything will seem to right but the part required for heating might be damaged internally...try changing tat...here i did the same...
Sep 19, 2008 | Frigidaire GLMV168K Microwave Oven
Mar 07, 2008 | Microwave Ovens
Microwave Ovens Logo
49 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
