Question about Canon imagePROGRAF iPF8000 Printer
We have recently purchased the iPF8000S. When the printer is networked it pauses on each line of the print job. When the printer is connected directly to the computer with a crossover cable the printer does not pause. When you plug in the network cable the light is green for only a second and then it turns to amber. Any help is greatly appreciated.
    Problem Solver:
  • 4 Answers
Cheers,
It may be a NW protocol/switch/router/driver issue. I print to my 8000s on USB 2.0, since the 8000s has no Gig E. But I had a few problems trying to connect to the Remote UI on separate network card with dedicated address. So in the end I left printer with dedicated address and plugged it into my el cheapo NW switch. The remote UI connected straight away via browsers URL to printers IP address. This way I can move files amongst mailboxes and rename them etc without affecting the print spools flowing via USB. Crossover cable should not be needed either on a modern device, since it should be more intelligent and realize the direct connection, auto switching pairs as needed. If you really need to drive 8000s on NW then I'd remove driver and try setting printer IP first via LCD, then forcing Garo driver installer to search and find the printer IP when re-installing its Garo driver.
Posted on Sep 22, 2010
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
Feb 08, 2011 | HP DeskJet 6988 Printer
When I try to print with my HP D4260 printer, it will not print solid colors - everything has banded lines. Can I fix this?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Deskjet D4260 Printer
My HP 1120cxi was workinh fine until i reinstalled windows XP pro. now it doesnt print. tried uninstalling and reinstalling the printer and driver, but it just prints 1 line of gibberish
  • Connectivity :
Oct 26, 2010 | HP Deskjet 1120c InkJet Printer
I have an HP Photosmart c4180 all-in-one printer. I just tried to install an HP98 cartridge refilled at Office Max. The printer responds with a message: "Cartridge not recognized". There is no...
  • Connectivity :
Oct 26, 2010 | HP Photosmart C4180 All-In-One InkJet...
Hi, there is a black line in the middle of the page after printing, do you know why?
  • Connectivity :
Oct 26, 2010 | HP Photosmart 8250 InkJet Printer
Black line on page
  • Connectivity :
Oct 26, 2010 | HP LaserJet 4 plus Printer
Recently my epson 9600 pauses during a printing job for long periods, so that it can take several hours to complete one print.
Need more info.
Are you printing from a computer directly attached to the 9600 ?
or
Are you printing through a network.
If you are using a networked printer then your print job could be slowed a good bit by heavy network traffic.
Apr 06, 2010 | Epson Stylus Pro 9600 InkJet Printer
Mystery Print Problem with Canon iPF8000
If it's within 12 months of purchase, Canon will replace free, although you may have to hound them a bit. This problem has occured twice (2 new heads) on our IPF8100 each time about 9 months in.
Mar 09, 2010 | Canon imagePROGRAF iPF8000 Printer
IPF610 Canon "Print head needs cleaning"
I've had the same problem, and finally after hours of frustration, got Canon to provide a new PrintHead at no charge
Jun 02, 2009 | Canon imagePROGRAF iPF8000 Printer
Printer keeps pausing itself!!
By UI do you mean RUI (Remote User Interface)? Have you installed a network kit? If so did you upgrade firmware using SST? If not, you need to do this or printing won't work.
In service mode. Copier > Display > Version > PS/PCL there needs to be a number e.g. 30.06. If there is no number the copier does not have any print drivers on it and won't be able to print. You also need to have a N BOOT-ROM (included in network kit). There Should be a N next to the number for BOOT-ROM under Copier > Display > Version if a N BOOT-ROM is installed.
Jan 14, 2009 | HP LaserJet 3330 All-In-One Printer
Canon imagePROGRAF  iPF8000 Printer Logo
233 people viewed this question
old marine
old marine
