Question about Canon iRC3100 Printer
Ir 3100 colour xerox i faced master copy centre white lines
  • 31 Answers
Hai my name is aslam u will change thr drum unit or ITB unit
Posted on Oct 14, 2010
Xerox IR 3300 Copy Quality Promblem
I believe you might have a Canon Imagerunner 3300, Xerox has a Phaser 3300mfp. Can you confirm the model and what is the quality problem, lines, dots, ghosting, etc.
Jan 14, 2016 | Xerox Office Equipment & Supplies
Darkness in botom part of pare in xerox copy only this is not appear in print by computer drum is all ready new
Then there is something wrong with the scanner. Have you tried cleaning the platen glass?
Feb 21, 2015 | Canon Ir 3300 Black & White Copier
Black colour lines in xerox only
Dear
If you have facing the problem while you made copy using ADF.then check th adf glass for scrathes replace it. If you have the problem while copy on platen glass then check lines on platen glass (rare case). Check cis for dust.
Thanks.
Jan 30, 2015 | Canon ImageRunner 4570 | IR4570 |
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Aug 08, 2014 | Xerox Workcentre 4250/SM Laser Printer,...
1) I have XEROX Document Centre 425DC, when ever I take a copy I find black lines on the print , Even on the blank paper 2) When I bought this machine I was told that this machine can be connected to the...
First of all clean the platten glass, also the narrow glass to the left of the platten glass. If the lines are still there after doing a copy,open the upper left cover and look at the fuser heat roller,the lines could be from a toner contaminated heat roller,this can be cleaned with a minerised scowering pad.with the copier switched on press the Key button then # 1 1,touch Enter on the touch screen.touch HSFI tab,scoll down to copies on cru and enter, if the count is above 20,000 the fault could be the cru ( copy cartridge) needs replacing as it is not cleaning the drum.
There is not a USB port on the 425 dc. If the copier has a ESS on top of the engine ( you should see a floppy disk drive slot on the front of the copier) it means it has been converted to a 425 ST, if not it will cost a to much to convert. A xerox 425 ST will connect to a computer. Xerox ST copiers means Networked
Jan 15, 2011 | Xerox Document Centre 420 DC Laser Printer
The print out r my xerox copier everytime we used it the print copy is dirty.how can i solve these kind of problem?hope you can help.thanks
The developing tank need,s also a periodical maintenance ( after about 150 - 170 K the dr. blade gets dirty and some white lines will appear on the copy and also you will have to clean the developing roller, i recommended with alcohol). The laser always gets dirty on the polygonal mirror and the optics, if in the room is enough dust.
Dec 11, 2010 | Canon iR 2016i Black and White Copier
Xerox Work Centre 7132 - when printing colour it is un-even ie; the top section of the page is faded but the bottom end is as it should be. Have removed & shaken all the colour barrels but it is still...
You have a bad developer housing . Most likely the magenta.
The developer housings have a tendency to have the screws inside the housing come loose and spew out the developer. That leaves an inadequate brush to apply the ink to the drum to make the correct copy.
You will need to have a technician come in, determine which housing is bad, order then replace that housing. It is a common problem on the 7132.
May 18, 2009 | Xerox Office Equipment & Supplies
White spots with a black dot in the centre
pls check the ibt belt. its geting any hole are bunch its come like this, or u will check and clean ibt assemply transfer rolleres. and 2nd btr also.
Jul 23, 2008 | Xerox DocuColor 12 Color Copier
Canon iRC3100 Printer Logo
162 people viewed this question
old marine
old marine
