Question about Sharper Image FJ450 Consumer Headphones
The foam is falling off my old ear pads. How do I find replacement pads?
Replacement foam ear pads
Yes you can. Go to my blog site and you will see a link to a place that sells them.
Apr 12, 2014 | Philips SBC HP400 Headphones CS01 Stereo...
My Motorola S305 stereo bluetooth headphones' foam pads on one of the ears is falling off. I've tried using something like a credit card to pinch the foam back into the game where it seems to be held in,...
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Sep 28, 2010 | Motorola Stereo Bluetooth Headphones
I've noticed that replacement inner foam(that covers the speakers) and earpads are available for my Sennheiser HD 570 Headphones; how do i get the old ones off? Thanks
The ear padding is attached to and held in place by a plastic ring that fits into the speaker mount. Gently pull the ear padding outward so you can see the ring, then slip a flathead screwdriver or other object in (just a bit, you don't want to poke the speaker inside). Gently pry up , sliding your pry-bar along, and the pad should pop out quite easily.
Sep 19, 2010 | Sennheiser HD 570 Consumer Headphones
Replacement foam for Beyerdynamic DT 531 Consumer Headphones
I have the same problem with a pair of Fostex Headphones. I have taken them apart and I have removed the rubber type ring that the foam fits over.
I am going to order a cheap pair of thin foam Headphone ear covers from Ebay. (They are available in various sizes) and stick the foam to the ring and follow that
by sticking the ring back in. Should work if the foam is thin enough. What do you think?
Eddie
Nov 27, 2008 | Beyerdynamic DT 531 Consumer Headphones
Need replacement earpads for Sony FM/AM Walkman SRF-H4 headset radio
LIKE YOU ALL, NO CURE OR REPLACEMENT FOR THE ROTTED PADS. WENT TO HOME DEPOT AND BOUGHT ECONOMY PLUS BRAND AIR CONDITIONER FILTER MATERIAL, ABOUT $3.00, FOR A WALL AC. THEN WENT TO DOLLAR GENERAL AND BOUGHT SCUNCI BRAND BLACK HAIR ELASTICS, EIGHT OF THEM FOR $2.00 TO KEEP PONYTAILS, NOW EAR PADS, IN PLACE. CUT THE AC MATERIAL TO FIT, AND ATTACHED WITH HAIR ELASTICS. ONLY A PURIST WOULD COMPLAIN ABOUT LACK OF COLOR MATCH. THERE WAS A SOLUTION, ONLY A MATTER OF FINDING IT. GOOD LUCK ALL OF YOU. R J BURNS, PENSACOLA, FL
Jul 17, 2008 | Audio Players & Recorders
Roger, ear pads are US $3.54 each. plus tax and shipping.
follow link:
http://servicesales.sel.sony.com/ecom/accessories/web/viewItemDetail.do?operation=getItemDetail&itemID=81781&searchOperation=modelSearch&searchText=SRFHM33
Good luck. I had the same problem.
Mar 20, 2008 | Sony SRF-H4 AM/FM/Weather/TV Radio
Sansui SH-15 Headphones - need foam ear pad cups - Toronto
Those headphones (I have a pair - they are rather nice, aren't they?) are over 30 years old and I doubt you'd be able to find any 'official' replacement pads. My suggestion would be to check out cheap headphones with the same sized pads and cannibalise them. If you do find any replacement pads specifically for the SH-15's, then I would also be buying a lottery ticket and maybe bet on a few horses, because you would have to be one lucky person.
Feb 05, 2008 | Radio Communications
Replacement ear pads
http://headsetpartsunlimited.com/orderinfo.html
Jan 24, 2008 | Logitech Internet Chat Consumer Headset
Sharper Image FJ450 Consumer Headphones Logo
158 people viewed this question
Top Sharper Image Audio Players & Recorders Experts
Tom Chichester
woodzowl307
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
