Question about Dryers
The dryer will not heat up every thing else seems to run fine
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Posted on Sep 14, 2010
Dle5977w will not heat
Check all Thermostats and fuses. Make sure there is 220v going to dryer. Heat circuit also runs through timer and motor.
Nov 01, 2017 | Dryers
Drier has no heat. Seems to run fine, otherwise. might I nee d to re-light the pilot through the small hole in the front of it?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Kenmore 60172 Electric Commercial Dryer
Model # pye2300ayw it seems to run fine but no heat?
heatman101
Jan 18, 2011 | Maytag PYE2300AY Electric Dryer
The dryer starts up and seems to run fine except that it doesn't heat.
heatman101
Dec 30, 2010 | Frigidaire GLER341A Electric Dryer
I HAVE A ZANUSSI TUMBLE DRYER TC 7103 W, ELEMENT SEEMS FINE, THERMO ALSO FINE BUT STILL NO HOT AIR BEEING CIRCULATED
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 20, 2010 | Zanussi TC7114W Electric Dryer
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Dryer runs but does not heat up
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
heatman101
Asker's Testimonial " Thanks for the feed back. Will order the part today. "
Apr 20, 2010 | Kenmore 65924 Electric Dryer
Everything seems fine but will not heat up I checked continuity, on every thing and it seems fine and I did the more less more less and all codes came up fine took the heating element out and it seems fine...
First things first...Are you sure that you have 220 volts to the dryer? Just because the motor runs doesn't neccesarily mean you have the proper voltage. Also check the connections where the cord comes in to see if they are tight and intact.
Apr 06, 2009 | Kenmore 63942 Dryer
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
Dryers Logo
41 people viewed this question
Top Dryers Experts
