Question about Amana Dishwashers
Does not seem to spray water inside. I have plenty of water pressure but just a little volume inside
  • 145 Answers
If you have good water to the unit with very little inside then you need to check the fill valve on the unit itself. They get plugged up fairly easy. They are easy to replace also with just the house line, one fill hose, two wires, and a couple screws.
Posted on May 16, 2008
Dishes and glasses not clean, seems like spray bars not turning water seems plenty ,no clogged filters
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Dec 13, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Not cleaning
Check spray arm jet holes. Clean the clogging with blower or soft bristles.
Apr 12, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Low water pressure. New installation, replacement
The posi temp valve has a little system built inside to anti scald you when your taking a shower, they have little parts that move back and forth, they get easily clogged from sediment and minerals in the water and always get stirred up when the water is turned off and back on from doing work.
Mar 17, 2010 | Moen Posi-Temp Single HandleTub And Shower...
The detergent packet doesn't dissolve. The dishwasher seems to go through the cycles ... the dishes are wet. However I find the detergent packet in the bottom of the dishwasher.
Hello- Water flow, temperature, and pressure inside determine whether this little packet will dissolve.  Sump blockages or pump /motor weakness both effect amount water spraying inside. Some of these packets don't dissolve in time to enter wash water. Start by using powder or gel again. If it still leaves soap residue, other pump/motor issues exist. Let me know if this info helps- have more if needed. Thanks- ED
Mar 09, 2010 | Frigidaire Dishwashers
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Poor cleaning leaving deposits,dishes feel dirty
The problem for the spots is hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Aug 04, 2009 | Thermador DW44Z Built-in Dishwasher
Low or no spray pressure
You sound like you diagnosed it pretty good, so I think you can change the impeller. The biggest problem is making sure everything is lined up so it wont leak after its re-installed. I've never had much luck removing the old impeller without breaking it into pieces. just be careful not to mess up the shaft. If its an older machine, some Whirlpool/Kenmore can have the whole thing changed in one part. Its a little more $$ but it has the motor and all. And its easier and faster!! Also, your pressure problem may be related to the motor.
Mar 15, 2008 | Whirlpool 24 in. DU920PW Built-In...
Dishwasher won't clean
IF WATER GOES IN MAYBE THE WATER DONT SPRAY AROUND MAYBE THE SPRAYER BLOCK REOVE AND CLEAN MAYBE DE BRIE INSIDE AIR PRESSURE WORK FINE FOR THAT CHEERS
Jan 17, 2008 | Dishwashers
Spray arm on KitchenAid KDC 17
water pressure should spin the arm. If it is not spinning and you have tub full of water-circulation pump could be the problem
Jan 05, 2008 | Dishwashers
Dishwashers Logo
Top Amana Dishwashers Experts
Oloyede Monsuru
Mike
Kolbrun...
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
